Uninstall Missing in Programs Control Panel
  1.    27 May 2007 #1
    RickB Guest
    I needed to uninstall a program. So, I went Start-->Control
    Panel-->Programs-->Uninstall a Program. Once the windo populated the
    "Uninstall" option was missing for all prgrams. There was only "Organinize"
    and "View."
    I'm lost, any ideas?
    Thanks, Rick
  2.    27 May 2007 #2
    JimR Guest
    Re: Uninstall Missing in Programs Control Panel
    "RickB" <RickB@discussions.microsoft.com> wrote in message
    news:1CA416C6-10BF-4CC1-AE64-31D73B5FC857@microsoft.com...
    > "Organinize"
    > and "View."
    > Thanks, Rick
    Highlight a listed program and the uninstall/change option should appear.
    Jim
  3.    27 May 2007 #3
    Texas, USA
    64-bit Windows 10 Pro
    Local Time: 10:27
    usa us oklahoma
    Hi Rick,
    I don't know on this one. If you don't know where the individual uninstall is for each program, you can download the Free CCleaner program & use it's Uninstall feature in a pinch until you get this resolved. It'll be under the Tools section in CCleaner. Here's the link:
    http://ccleaner.com/
    Hope this helps for now,
  4.    28 May 2007 #4
    Rock Guest
    > "Organinize"
    > and "View."
    Uninstall doesn't show up until you click on an individual entry in the
    list. Does that not happen?
    Rock [MS-MVP User/Shell]
  5.    28 May 2007 #5
    RickB Guest
    Hi Jim,
    Highlighted does not work, double clicking does nothing, right click does
    nothing.
    Suggestions? Thanks, Rick
    > > "Organinize"
    > > and "View."
    > > Thanks, Rick
    > Jim
  6.    28 May 2007 #6
    RickB Guest
    Thanks Shawn!
    "brink" wrote:
    > Hi Rick,
    > link:
    > '_http://ccleaner.com/_'
    > (http://ccleaner.com/)
    > Shawn
    > brink
    > "Practice makes perfect, then you reinstall"
    > '_www.Vistax64.com_' (http://www.vistax64.com/www.Vistax64.com)
    > Please post feedback to help others
  7.    28 May 2007 #7
    RickB Guest
    Highlighting does not work, double clicking does nothing, right clicking does
    nothing.
    Suggestions. Thanks, Rick
    > > "Organinize"
    > > and "View."
  8.    15 Jun 2007 #8
    Tony B Guest
    I have the same issue and although this works surely there is a fix for this
    in Windows or is the uninstall feature not an option in Vista?
    > nothing.
    > > > "Organinize"
    > > > and "View."
  9.    22 Aug 2007 #9
    Micky1701 Guest
    Same - issue - I have seen enough posts to convince me that there is an
    underlying issue here.
    Microsoft - please end the pain.
    > > nothing.
    > > > > "Organinize"
    > > > > and "View."
  10.    13 Feb 2009 #10
    In a box next to yours
    Vista Business 32
    Local Time: 04:27
    newzealand
    Haha! I have this issue as well, though it was via Ccleaner that I caused the problem.
    Went to clean PC, and uninstalled the Vista uninstaller via Ccleaner. I saw a green V named uninstaller under tools in Ccleaner. Figuring this was spyware I uninstalled that "uninstaller"
    Turns out I uninstalled the Vista uninstaller. No clue as to why MS made the uninstaller uninstallable. Ccleaner picked it up, and me never ever even thinking anything bad could happen from uninstalling something named uninstaller ended up now always having to use Ccleaner. Albeit with a lot more care haha
    Aah, I noticed I'm kinda like 2 years late here hehehe Ohw well. Maybe this has some use for others
it is sufficient to uninstall Norton Internet Security in the control panel folder??/
i have installed Nod32 antivirus in my computer. i have uninstalled norton internet security program by going into the control panel folder. is it...
Vista security
Cannot open Control Panel - Programs - Uninstall a Program
When I click on uninstall a program in control panel nothing happens. I don't get and error message or anything...just nothing. I am set up as...
Vista General
Control Panel Goes Missing
My Control Panel on Vista Home Premium has gone missing together with the Windows Update. Just a brief flash of an opening and closing window....
Vista General
Cannot Uninstall Programs through Control panel
When I attempt to uninstall certain unwanted programs an error windows pops up reporting: "The System administrator has set policies to prevent this...
Vista General
Can not uninstall software from control panel
Hi, I use Vista Business When I try to uninstall software from Control Panel it doesn't allow and also I can't see the manufactures logo sucha...
Vista account administration
Missing Data - Control Panel\Programs and Features
Greetings! I was out of the room while the machine was doing a routine backup tonight(Acronis® True Image Home® version 10.0), when I heard my...
Vista General
Vista Control Panel and removing programs
Hello, I just upgraded to Vista Home Premium and can't access the Control Panel. Whenever I try, I get a message that Windows Explorer has crashed....
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • Old server
    About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
