| | Desk top icon disappearing and recycle bin emptying I am running VISTA HOME PREMIUM. Hi, I re-customized my links in my browser (IE7) and restarted my computer for the changes to take effect. When my computer restarted a desk top icon had disappeared but I cant for the life of me work out which one (i right clicked a blank part of desk top/then clicked personalize/then clicked change desk top icons in the left pane but none of the icons in there where the 1 that had disappeared) I also noticed that my recyce bin had mysteriously emptied its self - I definitely did not empty the recycle bin. My computer is seemingly running fine and I have carried out a whole host of sucurity checks but everything comes back smelling of roses. Is there a tool that I can download and run to see if any files etc etc are missing from my system? Any advice from you guys would be most welcome. Thank you in advance ![]() |
| | Re: Desk top icon disappearing and recycle bin emptying Hi Gazzy-- You can run SFC that comes with Vista and several prior OS's but is changed in Vista under the hood. I would try running SFC and if you need to and have the Vista DVD (MSFT bullies most OEM named partners who sell PCs into not shipping it because they are greedy and lack ethics leaving their end users up a creek without a paddle when they need many of the tools to fix a no boot Vista). The man partially responsible for this is Scott Di Valerio the OEM VP at Redmond. He's the head of all the hard working OEM system builders and his computer engineering background consists of his accounting practice at MSFT--he done be accounting da money at the expense of the MSFT customer who pays one to four grand for a computer (except Dell with Vista). SFC or System File Checker is a bit like the spare tire in your car or a backup battery I suppose. In Vista of course, they have changed it somewhat and come up with a new name--Redmond stands for name it something different twice a year and now it's part of WRP or Windows Resource Protection. It scans protected resources including thousands of files, libraries, critical folders, and essential registry keys, and it replaces those that are corrupted with intact ones. It fixes a lot of problems in Windows XP, OE, Windows Vista, Win Mail, IE6, and on Vista or if it is installed on XP, IE7. It protects these things from changes by any source including administrators, by keeping a spare of most of them. How to Run SFC: Type "cmd" into the Search box above the Start Button>and when cmd comes up at the top of the Start menu>right click cmd and click "run as Admin" and when the cmd prompt comes up at the cmd prompt type "sfc /scannow" no quotes and let it run. This may fix things quite a bit. It replaces corrupt files with intact ones, if you're not familiar with it. If no help from SFC, you can try a restore point to before this happened or you try the steps below if you have a Vista DVD: Startup Repair will look like this when you put in the Vista DVD: http://www.vistaclues.com/wp-content...r-computer.png You run the startup repair tool this way (and system restore from here is also sometimes effective): http://support.microsoft.com/kb/925810/en-us How To Run Startup Repair In Vista Ultimate (Multiple Screenshots) http://www.windowsvista.windowsreins...rtup/index.htm I'm going to give you a bunch of links and most of them you won't have to use, but they are alternative ways to fix Vista. Right now I want you to put in the DVD and restart. It will automatically take you to this on your screen: http://www.vistaclues.com/wp-content...r-computer.png That will allow you to go to the Vista setup that has a Repair link on the lower left corner>click it and then you'll see a gray backgrounded list and I want you to click Startup Repair from it and follow the directions. The gray screen after you click the first link in the above pic will look like this: http://www.windowsreinstall.com/winv...ir/Image17.gif Click Startup Repair, the link at the top and after it scans>click OK and let it try to repair Vista. It will tell you if it does, and if not This should work, but if not,then you can follow the alternative ways to fix this including booting into Safe Mode by tapping the F8 key and using System Restore. Directions and links for alternative ways to fix this are below, but I hope you won't need them: If you have any questions on getting the Startup Repair done, just post them. If you have a Vista DVD try Startup Repair. If that doesn't work, try SafeMode>System Restore from the Recovery Environment, and you always have the F8 advanced options ( five of them including Last Known Good Configuration) and a repair install (with the DVD) as well. In addition you can use the Bootsect tool to manually repair the boot sector by accessing the command prompt from the DVD or from F8 and typing at the prompt: ****Ten Methods to Repair BSOD No Boots or Serious Problems in Windows Vista**** ***Startup Repair and System Restore from the Win Recovery Environment on the DVD*** You can run Startup Repair by putting your Vista DVD in after theanguage screen in setup. You can also run System Restore from the same location. You run the startup repair tool this way (and system restore from here is also sometimes effective): http://support.microsoft.com/kb/925810/en-us How To Run Startup Repair In Vista Ultimate (Multiple Screenshots) http://www.windowsvista.windowsreins...rtup/index.htm Note The computer must be configured to start from a CD or from a DVD. For information about how to configure the computer to start from a CD or from a DVD, see the information that came with the computer. 2. Restart the computer. To do this, click Start, click the arrow next to the Lock button, and then click Restart. This usually means that you enter bios setup by whatever key or keys (sometimes there is more than one key that will do it for your model--go to pc manufacturer site) and configure CD to be first in the boot order (this will allow you to boot from the Vista DVD as well): See for ref: Access/Enter Motherboard BIOS http://www.michaelstevenstech.com/bios_manufacturer.htm Boot Order in Bios (Set Boot from HD 1st) http://www.short-media.com/images/mm...ios/bios03.jpg Note If you cannot restart the computer by using this method, use the power button to turn off the computer. Then, turn the computer back on. 3. Set your language preference, and then click Next. Note In most cases, the startup repair process starts automatically, and you do not have the option to select it in the System Recovery Options menu. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options menu, click Startup Repair to start the repair process. 7. When the repair process is complete, click Finish. Additional References for Startup Repair With Screenshots: How to Use Startup Repair: ***Accessing Windows RE (Repair Environment):*** 1) Insert Media into PC (the DVD you burned) 2) ***You will see on the Vista logo setup screen after lang. options in the lower left corner, a link called "System Recovery Options."*** Screenshot: System Recovery Options (Lower Left Link) http://blogs.itecn.net/photos/liuhui...4/500x375.aspx Screenshot: (Click first option "Startup Repair" http://www.leedesmond.com/images/img...SysRecOpt2.bmp How To Run Startup Repair In Vista Ultimate (Multiple Screenshots) http://www.windowsvista.windowsreins...rtup/index.htm 3) Select your OS for repair. 4) Its been my experience that you can see some causes of the crash from theWin RE feature: You'll have a choice there of using: 1) Startup Repair 2) System Restore 3) Complete PC Restore ___________________ In addition you can use the Bootsect tool to manually repair the boot sector by accessing the command prompt from the DVD or from F8 and typing at the prompt: Bootsect.exe is available from the \Boot\folder of the Windows Vista DVD and can be run from within System Recovery or Windows XP on a dual boot. 1. Use Bootsect.exe to restore the Windows Vista MBR and the boot code that transfers control to the Windows Boot Manager program. To do this, type the following command at a command prompt: Drive:\boot\Bootsect.exe /NT60 All In this command, Drive is the drive where the Windows Vista installation media is located. Note The boot folder for this step is on the DVD drive. 2. Use Bcdedit.exe to manually create an entry in the BCD Boot.ini file for the earlier version of the Windows operating system. To do this, type the following commands at a command prompt. Note In these commands, Drive is the drive where Windows Vista is installed. • Drive:\Windows\system32\Bcdedit /create {ntldr} –d "Description for earlier Windows version" Note In this command, Description for earlier Windows version can be any text that you want. For example, Description for earlier Windows version can be "Windows XP" or "Windows Server 2003". • Drive:\Windows\system32\Bcdedit /set {ntldr} device partition=x: Note In this command, x: is the drive letter for the active partition. • Drive:\Windows\system32\Bcdedit /set {ntldr} path \ntldr • Drive:\Windows\system32\Bcdedit /displayorder {ntldr} –addlast 3. Restart the computer. ____________________________ ******Using the BootRec.exe Tool Using the System Recovery Tool from the Repair link on the DVD after the language choice in the lower left hand corner you can select command prompt and you have the following options: Bootrec.exe (You can use this tool to recover Vista even when you do not receive the error message that is the title of the 2nd linked MSKB below): How to use the Bootrec.exe tool in the Windows Recovery Environment to troubleshoot and repair startup issues in Windows Vista http://support.microsoft.com/kb/927392/en-us Error message when you start Windows Vista: "The Windows Boot Configuration Data file is missing required information" http://support.microsoft.com/kb/927391/en-us _____________________________________________________________ ***Using the F8 Environment or a Repair Install from the DVD:*** See for ref: Access/Enter Motherboard BIOS http://www.michaelstevenstech.com/bios_manufacturer.htm Boot Order in Bios (Set Boot from HD 1st) http://www.short-media.com/images/mm...ios/bios03.jpg Repair Install http://www.microsoft.com/windowsxp/u...ps/doug92.mspx Repair Install (Method 2): http://support.microsoft.com/default.aspx/kb/315341 III Taking Full Advantage of the F8 Options (Windows Advanced Options Menu) by startin gth ePC and tapping F8 once per second: You could also: Think: I have 4 different ways to get back my XP at F8 and try 'em in order. 1) Safe Mode 2) Safe Mode with Cmd to Sys Restore which is simply a cmd prompt in safe mode 3) Safe Mode with Neworking 4) LKG or Last Known Good Configuration Try to F8 to the Windows Adv Options Menu>try 3 safe modes there (I don't use WGA) and Last Known Good>then I go to Win RE in Vista. That gives you a choice of Safe Mode, Safe Mode with Networking,and Safe Mode with Command Prompt. These methods are outlined in A description of the Safe Mode Boot options in Windows XP/and Vista http://support.microsoft.com/kb/315222/ How to Use System Restore http://bertk.mvps.org/ Frequently Asked Questions Regarding System Restore from MSFT: http://www.microsoft.com/technet/pro.../faqsrwxp.mspx Using System Restore http://tinyurl.com/dvekb System Restore for Windows XP http://www.kellys-korner-xp.com/xp_restore.htm How to start the System Restore tool at a command prompt in Windows XP http://support.microsoft.com/default...b;en-us;304449 Repair Install: (This option has the best chance of succeeding and it preserves everything in your OS--you do not lose anything with this option): Make sure the DVD you have is a Vista DVD Pitfalls: If the DVD came from friend or relative or P2P, you may have problems. P2P besides being illlegal in many countries including the U.S. can be corrupt. If CD came from friend or relative, they may have given you the CD to use but if product key is in use, MSFT is not going to accept it for activation. Make sure you clean the CD carefully using proper cleaning fluid and strokes that radiate from center like spokes on a wheel. Again a repair install has the most likely chance to succeed in XP, (and can work in Vista) but you need to have a Vista DVD. First, in order to do a Repair Install You must boot to the bios setup and position booting from the "CD" first in the boot order--it probably will not say DVD but might. Booting to Bios Setup: For 85% of PC's and all Dells you can tap the F2 key to reach bios setup. How To Enable DVD/CD Rom Support (put CD boot first) in bios setup boot order: http://xphelpandsupport.mvps.org/how..._support_i.htm Screen Shot of bios setup boot order: http://www.poy.net/proxy/bios2.jpg Repair Install Does Not Lose Anything; you may need to try 2-3 times but that's rare. How To Repair Install http://support.microsoft.com/kb/3153...22120121120120 Screen Shot Repair Install http://www.windowsreinstall.com/winx...exfullpage.htm Good luck, CH Go Danica--beat them ole boys this time! Use the draft. Apathetic America shopping and running gas guzzlers, their Congress and their moron leader are making lots more of these in the next few years: Photos of Military Coffins (Battlefield and Astronaut Fatalities) at Dover Air Force Base http://www.thememoryhole.org/war/coffin_photos/dover/ War Without End NYT Editorial Never mind how badly the war is going in Iraq. President Bush has been swaggering around like a victorious general because he cowed a wobbly coalition of Democrats into dropping their attempt to impose a time limit on his disastrous misadventure. By week's end, Mr. Bush was acting as though that bit of parliamentary strong-arming had left him free to ignore not just the Democrats, but also the vast majority of Americans, who want him to stop chasing illusions of victory and concentrate on how to stop the sacrifice of young Americans' lives. And, ever faithful to his illusions, Mr. Bush was insisting that he was the only person who understood the true enemy. Speaking to graduates of the Coast Guard Academy, Mr. Bush declared that Al Qaeda is "public enemy No. 1" in Iraq and that "the terrorists' goal in Iraq is to reignite sectarian violence and break support for the war here at home." The next day, in the Rose Garden, Mr. Bush turned on a reporter who had the temerity to ask about Mr. Bush's declining credibility with the public, declaring that Al Qaeda is "a threat to your children" and accusing him of naïvely ignoring the danger. It's upsetting to think that Mr. Bush believes the raging sectarian violence in Iraq awaits reigniting, or that he does not recognize that Americans' support for the war broke down many bloody months ago. But we have grown accustomed to this president's disconnect from reality and his habit of tilting at straw men, like Americans who don't care about terrorism because they question his mismanagement of the war or don't worry about what will happen after the United States withdraws, as it inevitably must. The really disturbing thing about Mr. Bush's comments is his painting of the war in Iraq as an obvious-to-everyone-but-the-wrongheaded fight between the United States and a young Iraqi democracy on one side, and Al Qaeda on the other. That fails to acknowledge that the Shiite-dominated government of Iraq is not a democracy and is at war with many of its own people. And it removes all pressure from the Iraqi leadership - and Mr. Bush - to halt the sectarian fighting and create a real democracy. There is no doubt that organized Islamist terrorism - call it Al Qaeda or by any other name - is a dire threat. There is also no doubt that terrorists entered Iraq - mostly after the war began. We, too, believe that Iraq has to be made as stable as possible so the United States can withdraw its troops without unleashing even more chaos and destruction. But Mr. Bush is not doing that and his version of reality only makes it more unlikely. The only solution lies with the Iraqi leaders, who have to stop their sectarian blood feud and make a real attempt to form a united government. That is their best chance to stabilize the country, allow the United States to withdraw and, yes, battle Al Qaeda. The Democrats who called for imposing benchmarks for political progress on the Iraqis, combined with a withdrawal date for American soldiers, were trying to start that process. It's a shame they could not summon the will and discipline to keep going, but we hope they have not given up. As disjointed as the Democrats have been, their approach makes far more sense than Mr. Bush's denial of Iraq's civil war and his war-without-end against terror. FRANK RICH: Operation Freedom From Iraqis WHEN all else fails, those pious Americans who conceived and directed the Iraq war fall back on moral self-congratulation: at least we brought liberty and democracy to an oppressed people. But that last-ditch rationalization has now become America's sorriest self-delusion in this tragedy. However wholeheartedly we disposed of their horrific dictator, the Iraqis were always pawns on the geopolitical chessboard rather than actual people in the administration's reckless bet to "transform" the Middle East. From "Stuff happens!" on, nearly every aspect of Washington policy in Iraq exuded contempt for the beneficiaries of our supposed munificence. Now this animus is completely out of the closet. Without Donald Rumsfeld and Paul Wolfowitz to kick around anymore, the war's dead-enders are pinning the fiasco on the Iraqis themselves. Our government abhors them almost as much as the Lou Dobbs spear carriers loathe those swarming "aliens" from Mexico. Iraqis are clamoring to get out of Iraq. Two million have fled so far and nearly two million more have been displaced within the country. (That's a total of some 15 percent of the population.) Save the Children reported this month that Iraq's child-survival rate is falling faster than any other nation's. One Iraqi in eight is killed by illness or violence by the age of 5. Yet for all the words President Bush has lavished on Darfur and AIDS in Africa, there has been a deadly silence from him about what's happening in the country he gave "God's gift of freedom." It's easy to see why. To admit that Iraqis are voting with their feet is to concede that American policy is in ruins. A "secure" Iraq is a mirage, and, worse, those who can afford to leave are the very professionals who might have helped build one. Thus the president says nothing about Iraq's humanitarian crisis, the worst in the Middle East since 1948, much as he tried to hide the American death toll in Iraq by keeping the troops' coffins off-camera and staying away from military funerals. But his silence about Iraq's mass exodus is not merely another instance of deceptive White House P.R.; it's part of a policy with a huge human cost. The easiest way to keep the Iraqi plight out of sight, after all, is to prevent Iraqis from coming to America. And so we do, except for stray Shiites needed to remind us of purple fingers at State of the Union time or to frame the president in Rose Garden photo ops. Since the 2003 invasion, America has given only 466 Iraqis asylum. Sweden, which was not in the coalition of the willing, plans to admit 25,000 Iraqis this year alone. Our State Department, goaded by January hearings conducted by Ted Kennedy, says it will raise the number for this year to 7,000 (a figure that, small as it is, may be more administration propaganda). A bill passed by Congress this month will add another piddling 500, all interpreters. In reality, more than 5,000 interpreters worked for the Americans. So did tens of thousands of drivers and security guards who also, in Senator Kennedy's phrase, have "an assassin's bull's-eye on their backs" because they served the occupying government and its contractors over the past four-plus years. How we feel about these Iraqis was made naked by one of the administration's most fervent hawks, the former United Nations ambassador John Bolton, speaking to The Times Magazine this month. He claimed that the Iraqi refugee problem had "absolutely nothing to do" with Saddam's overthrow: "Our obligation was to give them new institutions and provide security. We have fulfilled that obligation. I don't think we have an obligation to compensate for the hardships of war." Actually, we haven't fulfilled the obligation of giving them functioning institutions and security. One of the many reasons we didn't was that L. Paul Bremer's provisional authority staffed the Green Zone with unqualified but well-connected Republican hacks who, in some cases, were hired after they expressed their opposition to Roe v. Wade. The administration is nothing if not consistent in its employment practices. The assistant secretary in charge of refugees at the State Department now, Ellen Sauerbrey, is a twice-defeated Republican candidate for governor of Maryland with no experience in humanitarian crises but a hefty résumé in anti-abortion politics. She is to Iraqis seeking rescue what Brownie was to Katrina victims stranded in the Superdome. Ms. Sauerbrey's official line on Iraqi refugees, delivered to Scott Pelley of "60 Minutes" in March, is that most of them "really want to go home." The administration excuse for keeping Iraqis out of America is national security: we have to vet every prospective immigrant for terrorist ties. But many of those with the most urgent cases for resettlement here were vetted already, when the American government and its various Halliburton subsidiaries asked them to risk their lives by hiring them in the first place. For those whose loyalties can no longer be vouched for, there is the contrasting lesson of Vietnam. Julia Taft, the official in charge of refugees in the Ford administration, reminded Mr. Pelley that 131,000 Vietnamese were resettled in America within eight months of the fall of Saigon, despite loud, Dobbs-like opposition at the time. In the past seven months, the total number of Iraqis admitted to America was 69. The diplomat Richard Holbrooke, whose career began during the Vietnam War, told me that security worries then were addressed by a vetting process carried out in safe, preliminary asylum camps for refugees set up beyond Vietnam's borders in Asia. But as Mr. Holbrooke also points out in the current Foreign Affairs magazine, the real forerunner to American treatment of Iraqi refugees isn't that war in any case, but World War II. That's when an anti-Semitic assistant secretary of state, Breckinridge Long, tirelessly obstructed the visa process to prevent Jews from obtaining sanctuary in America, not even filling the available slots under existing quotas. As many as 75,000 such refugees were turned away before the Germans cut off exit visas to Jews in late 1941, according to Howard Sachar's "History of the Jews in America." Like the Jews, Iraqis are useful scapegoats. This month Mr. Bremer declared that the real culprits for his disastrous 2003 decision to cleanse Iraq of Baathist officials were unnamed Iraqi politicians who "broadened the decree's impact far beyond our original design." The Republican leader in the Senate, Mitch McConnell, is chastising the Iraqis for being unable "to do anything they promised." The new White House policy, as Zbigniew Brzezinski has joked, is "blame and run." It started to take shape just before the midterm elections last fall, when Mr. Rumsfeld wrote a memo (propitiously leaked after his defenestration) suggesting that the Iraqis might "have to pull up their socks, step up and take responsibility for their country." By January, Mr. Bush was saying that "the Iraqi people owe the American people a huge debt of gratitude" and wondering aloud "whether or not there is a gratitude level that's significant enough in Iraq." In February, one of the war's leading neocon cheerleaders among the Beltway punditocracy lowered the boom. "Iraq is their country," Charles Krauthammer wrote. "We midwifed their freedom. They chose civil war." Bill O'Reilly and others now echo this cry. The message is clear enough: These ungrateful losers deserve everything that's coming to them. The Iraqis hear us and are returning the compliment. Whether Prime Minister Nuri al-Maliki is mocking American demands for timelines and benchmarks, or the Iraqi Parliament is setting its own timeline for American withdrawal even while flaunting its vacation schedule, Iraq's nominal government is saying it's fed up. The American-Iraqi shotgun marriage of convenience, midwifed by disastrous Bush foreign policy, has disintegrated into the marriage from hell. While the world waits for the White House and Congress to negotiate the separation agreement, the damage to the innocent family members caught in the cross-fire is only getting worse. Despite Mr. Bush's May 10 claim that "the number of sectarian murders has dropped substantially" since the surge began, The Washington Post reported on Thursday that the number of such murders is going up. For the Americans, the cost is no less dear. Casualty figures confirm that the past six months have been the deadliest yet for our troops. While it seems but a dim memory now, once upon a time some Iraqis did greet the Americans as liberators. Today, in fact, it is just such Iraqis - not the local Iraqi insurgents the president conflates with Osama bin Laden's Qaeda in Pakistan - who do want to follow us home. That we are slamming the door in their faces tells you all you need to know about the real morality beneath all the professed good intentions of Operation Iraqi Freedom. Though the war's godfathers saw themselves as ridding the world of another Hitler, their legacy includes a humanitarian catastrophe that will need its own Raoul Wallenbergs and Oskar Schindlers if lives are to be saved. MAUREEN DOWD: Bush's Fleurs du Mal WASHINGTON For me, the saddest spot in Washington is the inverted V of the black granite Vietnam wall, jutting up with the names of young men dying in a war that their leaders already knew could not be won. So many died because of ego and deceit - because L.B.J. and Robert McNamara wanted to save face or because Henry Kissinger wanted to protect Nixon's re-election chances. Now the Bush administration finds itself at that same hour of shame. It knows the surge is not working. Iraq is in a civil war, with a gruesome bonus of terrorists mixed in. April was the worst month this year for the American military, with 104 soldiers killed, and there have been about 90 killed thus far in May. The democracy's not jelling, as Iraqi lawmakers get ready to slouch off for a two-month vacation, leaving our kids to be blown up. The top-flight counterinsurgency team that President Bush sent in after long years of pretending that we'd "turned the corner" doesn't believe there's a military solution. General Petraeus is reduced to writing an open letter to the Iraqi public, pleading with them to reject sectarianism and violence, even as the Shiite cleric Moktada al-Sadr slinks back from four months in Iran, rallying his fans by crying: "No, no, no to Satan! No, no, no to America! No, no, no to occupation! No, no, no to Israel!" W. thinks he can save face if he keeps taunting Democrats as the party of surrender - just as Nixon did - and dumps the Frankenstate he's created on his successor. "The enemy in Vietnam had neither the intent nor the capability to strike our homeland," he told Coast Guard Academy graduates. "The enemy in Iraq does. Nine-eleven taught us that to protect the American people we must fight the terrorists where they live so that we don't have to fight them where we live." The president said an intelligence report (which turned out to be two years old) showed that Osama had been trying to send Qaeda terrorists in Iraq to attack America. So clearly, Osama is capable of multitasking: Order the killers in Iraq to go after American soldiers there and American civilians here. There AND here. Get it, W.? The president is on a continuous loop of sophistry: We have to push on in Iraq because Al Qaeda is there, even though Al Qaeda is there because we pushed into Iraq. Our troops have to keep dying there because our troops have been dying there. We have to stay so the enemy doesn't know we're leaving. Osama hasn't been found because he's hiding. The terrorists moved into George Bush's Iraq, not Saddam Hussein's. W.'s ranting about Al Qaeda there is like planting fleurs du mal and then complaining your garden is toxic. The president looked as if he wanted to smack David Gregory when the NBC reporter asked him at the news conference Thursday if he could still be "a credible messenger on the war" given all the mistakes and all the disillusioned Republicans. "I'm credible because I read the intelligence, David," he replied sharply. But he isn't and he doesn't. Otherwise he might have read "Bin Laden Determined to Strike in U.S." in August 2001, and might have read the prewar intelligence reports the Senate just released that presciently forecast the horrors in store for naïve presidents who race to war because they want to be seen as hard, not soft. Intelligence analysts may have muffed the W.M.D. issue, but they accurately predicted that implanting democracy in Iraq would be an "alien" idea that could lead to turbulence and violence; that Al Qaeda would hook up with Saddam loyalists and "angry young recruits" to militant Islam to "wage guerrilla warfare" on American forces, and that Iran and Al Qaeda would be the winners if the Bushies botched the occupation. W. repeated last week that he would never retreat, but his advisers are working on ways to retreat. After the surge, in lieu of strategy, come the "concepts." Condi Rice, Bob Gates and generals at the Pentagon are talking about long-range "concepts" for reducing forces in Iraq, The Times reported yesterday, as a way to tamp down criticism, including from Republicans; it is also an acknowledgment that they can't sustain the current force level there much longer. The article said that officials were starting to think about how to halve the 20 American combat brigades in Iraq, sometime in the second half of 2008. As the Hollywood screenwriter said in "Annie Hall": "Right now it's only a notion, but I think I can get money to make it into a concept and later turn it into an idea." http://johnedwards.com/news/speeches/20060622/ Jun 22, 2006 Senator John Edwards Washington, DC "GazzyD" <GazzyD@discussions.microsoft.com> wrote in message news:8C0FD458-E854-4D4D-B291-C15B4AA7C51A@microsoft.com... >I am running VISTA HOME PREMIUM. Hi, I re-customized my links in my >browser > (IE7) and restarted my computer for the changes to take effect. When my > computer restarted a desk top icon had disappeared but I cant for the life > of > me work out which one (i right clicked a blank part of desk top/then > clicked > personalize/then clicked change desk top icons in the left pane but none > of > the icons in there where the 1 that had disappeared) I also noticed that > my > recyce bin had mysteriously emptied its self - I definitely did not empty > the > recycle bin. My computer is seemingly running fine and I have carried out > a > whole host of sucurity checks but everything comes back smelling of roses. > Is there a tool that I can download and run to see if any files etc etc > are > missing from my system? Any advice from you guys would be most welcome. > Thank you in advance ![]() |
| recycle bin keeps emptying | Vista General | |||
| Recycle Bin Keeps Emptying on it's Own | Vista General | |||
| Recycle Bin Icon Disappearing | Vista General | |||
| Recycle bin icon not filling/emptying when recycle bin is full/emp | Vista General | |||
| Recycle bin icon disappearing from desktop | Vista General | |||
