Vista - Toshiba Remote Control - Need Drivers, Please Help!
Old 05-28-2007   #1 (permalink)
cvs
I'm currenty using Toshiba Setallite M100 (PSMAOA-00G006), I bought it
last year. My computer is using Windows XP, I upgraded it to Windows
Vista last week but when I did, my remote control are not working.
Does anyone have any idea for this problem???? please help me out...
Thank you.
cvs
cvs's Profile: http://forums.techarena.in/member.php?userid=26091
View this thread: http://forums.techarena.in/showthread.php?t=755289
Old 05-28-2007   #2 (permalink)
Malke
Re: Toshiba Remote Control - Need Drivers, Please Help!
The remote control feature needs drivers and/or specialized software, as
you know. The only place to get the drivers is from Toshiba. Look on
Toshiba's website for your specific model laptop or contact their tech
support. If Toshiba does not plan to release drivers for your laptop,
then specialized laptop functions like the remote control will not work
under Vista. If it is important to you, remove Vista and go back to XP.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Drivers went missing IR remote control Drivers
where are vista pre-installed remote control drivers+registry entr Vista file management
toshiba drivers Vista print fax & scan
Toshiba Tecra M5 Drivers Vista hardware & devices
Bluetooth drivers from TOSHIBA? Vista hardware & devices
