Vista Tutorial - System notification icons & pointer settings won't stay put!
Old 05-29-2007   #1 (permalink)
CJSnet
Guest
I have Vista Ultimate and note the following issues. Is anyone able to
suggest a fix?:
1. The notification icons (volume, network, power) intermittently disappear
and are greyed out in the taskbar properties. This was an issue in XP and
really thought this 'new' OS would resolve it.
2. Automatically hide mouse pointer when typing also never worked in XP,
and continues not to work in Vista. Any other intellipoint drivers or
something I can try? 3rd party utils are either charged for or don't work
in Vista. This is supposed to work in the OS I paid for.
3. Automatically move pointer to dialog boxes also keeps unticking itself
after every reboot.
Hope someone is able to shed some light.
Thanks,
CJSnet
Recommended:
* http://search.superhighstreet.com - Finds anything or they pay!
* http://www.superhighstreet.com & http://www.oxfordstreet.com - Beat the
crowds with Virtual Streetscapes
[remove 'teeth' to e-mail me]
Old 05-29-2007   #2 (permalink)
MS-Adict
Guest
RE: System notification icons & pointer settings won't stay put!
You are posting from the future !
Is this on purpose in order to come on top of the list ?
> suggest a fix?:
> after every reboot.
> Thanks,
> CJSnet
> Recommended:
Old 05-29-2007   #3 (permalink)
CJSnet
Guest
Re: System notification icons & pointer settings won't stay put!
No idea what you mean - it says it was sent 29/05/07 13:21.
Anyway, if anyone can help...
"MS-Adict" <MSAdict@discussions.microsoft.com> wrote in message
news:B182D17F-1E26-4CE3-9F81-E76AEF5C6452@microsoft.com...
>> suggest a fix?:
>> disappear
>> and
>> work
>> itself
>> after every reboot.
>> Thanks,
>> CJSnet
>> Recommended:
>> the
Old 05-30-2007   #4 (permalink)
Mike Matheny
Guest
MS-Adict formulated the question :
>> suggest a fix?:
>> after every reboot.
>> Thanks,
>> CJSnet
>> Recommended:
MS-Adict - your news server or newsreader is not changing the posting time to
the local time - it's not them posting in the future - it's a misconfiguration
on your end!
Mike Matheny
Notification Area - System Icons Tutorials
How can I hide one or two system icons from Notification Area? General Discussion
System Icons Missing in Notification Area!!! Vista General
Customize Notification Icons: How to get settings to stick? Vista General
Customize notification icons settings lost after a few hours. Vista General
