Vista - Problems after installing update
Old 05-29-2007   #1 (permalink)
Stephen Croft
I have just upgraded to Vista, and I am getting daily updates. The last lot
is causing a problem in IE. I try to start it up and it does start. As soon
as my homepage is found it just closes down. At the moment I am using system
restore to get back to the last working point.
These are the 6 listed as imprtant updates. any ideas please?
Cumulative Security Update for Internet Explorer 7 in Windows Vista (KB931768)
Security Update for Windows Vista (KB925902)
Windows Malicious Software Removal Tool - May 2007 (KB890830)
Security Update for Windows Vista (KB930178)
Update for Windows Media Format 11 SDK for Windows Vista (KB929399)
Update for Windows Vista (KB930857)
Regards, Steve
Old 05-29-2007   #2 (permalink)
Hoock The Spook
Re: Problems after installing update
I"Stephen Croft" <StephenCroft@discussions.microsoft.com> wrote in message
news:36F2984E-FAFA-49AD-AEA3-26FBD50959C6@microsoft.com...
> soon
> system
> (KB931768)
> Regards, Steve
Guess one option would be to uninstall each update one at a time and then
see which one is causing the problem..!
The CONTROL PANAL x PROGRAMS AND FEATURES (add/remove) doesn't list the
Windows updates so you need another uninstaller to get rid of
them.................... "regedit" is as good as any and can be downloaded
http://www.tucows.com/get/32376_
Once you isolate the offending update go into the WINDOWS UPDATE settings
and uncheck the problem one to avoid it being downloaded all the time with
newer updates.
Old 05-29-2007   #3 (permalink)
Max
">The CONTROL PANEL x PROGRAMS AND FEATURES (add/remove) doesn't list the
> Windows updates so you need another uninstaller to get rid of them"
No you don't.
Open Windows Update.
Under "See Also" in the left pane bottom, click Installed Updates.
Uninstall whatever you want from there.
Maxwell Bluemeanie
"Hoock The Spook" <lurfmaster@hotmail.com> wrote in message
news:OrIERBmoHHA.668@TK2MSFTNGP05.phx.gbl...
> from:
> newer updates.
Old 05-30-2007   #4 (permalink)
Michael Solomon
>>lot
>> soon
>> system
>> (KB931768)
>> Regards, Steve
> from:
> newer updates.
Control Panel\Programs, click View Installed Updates in the Task Panel, the
column on the left side.
Michael Solomon
Backup is a PC user's best friend
DTS-L.Org: http://www.dts-l.org/
Old 05-30-2007   #5 (permalink)
Stephen Croft
Thanks all, esp Max
Regards, Steve
> No you don't.
> Maxwell Bluemeanie
> > from:
> > newer updates.
Old 05-30-2007   #6 (permalink)
Stephen Croft
RE: Problems after installing update
It was KB 931768, an IE7 upgrade that was my problem.
Regards, Steve
Win Update and stand alone update problems Windows Updates
Installing .net 3.5 update - gives me problems Vista installation & setup
Update not installing Vista General
Problems with Access 2002 (XP) After Installing Update Vista performance & maintenance
installing update 7... HELP! Vista installation & setup
