Vista Tutorial - No sound??????
Old 05-31-2007   #1 (permalink)
ALEX
Guest
No sound??????
I changed my computer to vista, and then I noticed that there is no sound!!!
So I went to sound prefrences and it said I have two devices (I only had
One!!!)
the one i dont have was working fine but the speaker are not connected.
So I disconnected the speakers and plugged them again, and still no result.
I went to help center and didnt find anything helpful.
P.S. When I had XP every thing worked fine
Old 05-31-2007   #2 (permalink)
Bill Yanaire
Guest
Re: No sound??????
Go to the manufacturers site and download the latest drivers for your sound
card. If it's on the motherboard, download drivers from their site.
"ALEX" <ALEX@discussions.microsoft.com> wrote in message
news:80E0EAD9-3E55-46C8-A3D5-4287EA189AE6@microsoft.com...
>sound!!!
> One!!!)
> result.
Old 05-31-2007   #3 (permalink)
Cal Bear '66
Guest
Re: No sound??????
Have you tried DELETING BOTH sound devices in Device Manager and then rebooting.
Also, have you downloaded the latest Vista drivers for your audio adapter? What
is your audio adapter?
> One!!!)
Old 06-01-2007   #4 (permalink)
ALEX
Guest
Re: No sound??????
I dont know, How do I check
> > One!!!)
Old 06-01-2007   #5 (permalink)
Cal Bear '66
Guest
Re: No sound??????
Control Panel > Device Manager, click + sign to expand Sound, video and game
controllers. There should be an entry (2?) with something like Realtek High
Definition, Sigma Tel, etc.
Post back with what you find and if you have duplicate entries for the same
device.
news:088AD2C9-37BD-4D6D-85BE-802BDD57E5C8@microsoft.com...
>> rebooting.
>> What
>> >sound!!!
>> > One!!!)
distorted sound in vista/createiv x-fi titanium sound card Sound & Audio
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Setting per Application Sound Output, or Per Sound Type Outputs... Vista General
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
