| | System not able to create restore points I just opened up System Restore for the first time on my Vista Ultimate x64 system only to find that NO restore points had ever been created. So I immediately tried to create a manual restore point only to get this error: The restore point could not be created for the following reason: The shadow copy provider had an unexpected error while trying to process the specified operation. (0x8004230F) Please try again. Does anyone know what this means or how to resolve it? There is plenty of disk space available on the system partition. -- And loving it, -Q _________________________________________________ Qu0llSixFour@gmail.com (Replace the "SixFour" with numbers to email me) |
| | Re: System not able to create restore points Hi QuOIl-- Sometimes but not always, restarting the pc makes this error disappear. I don't know a percent of times that has efficacy. This error has been a frequent topic of numerous groups and forums, and I haven't seen a clearcut explanation. MSFT is well aware this has been happening, probably a byproduct of the many shortcuts made in a frantic effort to get Vista to RTM instead of taking 6 more months as many of us repeatedly urged them to do. We were completely ignored as were many bug reports. Jill Zoeller [MSFT] who communicates to newsgroups for the Windows Core File Services team and also works closely with members of the System Restore teams and other related teams' responses to this error in the past have requested that people email her the contents of these two logs: Windows\Logs\WindowsBackup and \Windows\Logs\CompletePC. A search of Jill's Blog shows no discussion of a solution or solutions for this error and a new interface for the blog: The Filing Cabinet An IT Pro blog about file services and storage features in Windows Server, Windows XP, and Windows Vista http://blogs.technet.com/filecab/ I don't know the current status of this error with MSFT and the error may repesent more than one type of problem. I don't know what Jill and the people who work with her have been seeing in the logs they have examined. You might search her blog but I don't see an answer there: I don't see this problem addressed on a Beta Chat with the SR team either: http://blogs.technet.com/filecab/pages/447166.aspx Jill has also requested when she has responded on this error: Please contact me via email (remove "online") and include the following: 1. The problem description you put below. 2. A screenshot of your Disk Management screen showing disks and volumes. 3. Zip up the contents of %windir%\logs\windowsbackup\ 4. Generate a log file using the instructions below and email it to me: Under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Asr, create a new key called LogFileSetting Under LogFileSetting, create a new DWORD value called EnableLogging. Right-click that value, click Modify, and then enter 00000001 (hexadecimal) or 1 (decimal) Under LogFileSetting, create a new String value called LogPathName. Right-click that value, click Modify, and then enter C:\asr.log. Next, reproduce the error. You should have a file called asr.log under c:\. You might want to try searching Jill's Blog for this error. I didn't find any info. I did find discussions of what happens when there is not sufficient space to create a restore point. Good luck, CH "Qu0ll" <Qu0llSixFour@gmail.com> wrote in message news:O1j1xKSpHHA.2044@TK2MSFTNGP04.phx.gbl... >I just opened up System Restore for the first time on my Vista Ultimate x64 >system only to find that NO restore points had ever been created. So I >immediately tried to create a manual restore point only to get this error: > > The restore point could not be created for the following reason: > > The shadow copy provider had an unexpected error while trying to process > the specified operation. (0x8004230F) > > Please try again. > > Does anyone know what this means or how to resolve it? There is plenty of > disk space available on the system partition. > > -- > And loving it, > > -Q > _________________________________________________ > Qu0llSixFour@gmail.com > (Replace the "SixFour" with numbers to email me) |
| | Re: System not able to create restore points "Chad Harris" <vistaneedsmuchowork.net> wrote in message news:e73fehSpHHA.4772@TK2MSFTNGP05.phx.gbl... > Hi QuOIl-- > > Sometimes but not always, restarting the pc makes this error disappear. I > don't know a percent of times that has efficacy. > > This error has been a frequent topic of numerous groups and forums, and I > haven't seen a clearcut explanation. > > MSFT is well aware this has been happening, probably a byproduct of the > many shortcuts made in a frantic effort to get Vista to RTM instead of > taking 6 more months as many of us repeatedly urged them to do. We were > completely ignored as were many bug reports. > > Jill Zoeller [MSFT] who communicates to newsgroups for the Windows Core > File Services team and also works closely with members of the System > Restore teams and other related teams' responses to this error in the past > have > requested that people email her the contents of these two logs: > > Windows\Logs\WindowsBackup and > \Windows\Logs\CompletePC. > > A search of Jill's Blog shows no discussion of a solution or solutions for > this error and a new interface for the blog: > > The Filing Cabinet An IT Pro blog about file services and storage features > in Windows Server, Windows XP, and Windows Vista > http://blogs.technet.com/filecab/ > > > > I don't know the current status of this error with MSFT and the error may > repesent more than one type of problem. I don't know what Jill and the > people who work with her have been seeing in the logs they have examined. > You might search her blog but I don't see an answer there: > > I don't see this problem addressed on a Beta Chat with the SR team either: > http://blogs.technet.com/filecab/pages/447166.aspx > > Jill has also requested when she has responded on this error: > > Please contact me via email (remove "online") and include the following: > > 1. The problem description you put below. > 2. A screenshot of your Disk Management screen showing disks and volumes. > 3. Zip up the contents of %windir%\logs\windowsbackup\ > 4. Generate a log file using the instructions below and email it to me: > > Under HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Asr, > create a new key called LogFileSetting > > Under LogFileSetting, create a new DWORD value called EnableLogging. > Right-click that value, click Modify, and then enter 00000001 > (hexadecimal) > or 1 (decimal) > > Under LogFileSetting, create a new String value called LogPathName. > Right-click that value, click Modify, and then enter C:\asr.log. > > Next, reproduce the error. You should have a file called asr.log under > c:\. > > You might want to try searching Jill's Blog for this error. I didn't find > any info. I did find discussions of what happens when there is not > sufficient space to create a restore point. > > Good luck, > > CH OK thanks Chad for the effort to give such a detailed reply. It's not a complete disaster for me as I take an image of the disk every night using Acronis True Image so if I need to go back to a previous point I simply restore from a saved image. However, it may point to a more serious problem and I would really like to find a solution. -- And loving it, -Q _________________________________________________ Qu0llSixFour@gmail.com (Replace the "SixFour" with numbers to email me) |
| Newbie nable to find or create system restore points | Vista General | |||
| Unable to create restore points | Vista performance & maintenance | |||
| Can't Create Restore Points | Vista General | |||
| Can't create restore points | Vista performance & maintenance | |||
| Can't create system restore points | Vista General | |||
