Vista - USB hardware re-appears after "safe removal"
Old 06-02-2007   #1 (permalink)
Rald
After clicking on the "Safely Remove Hardware" icon and clicking my
external USB harddrive, I removed my external hard drive.
After rebooting, the vista device manager shows that the external
drive is attached even though nothing is plugged into the USB port.
I have tried uninstalling the driver without success. Thanks for any
suggestions.
Old 06-02-2007   #2 (permalink)
PaulB
RE: USB hardware re-appears after "safe removal"
Under View in the device manager, make sure that "Show hidden devices" is not
checked.
Paul
> suggestions.
Junk Mail "Delete and Block" option and "Safe List" Live Mail
Subject: Vista question about "compatibility mode" and "safe mode" Vista General
Vista: How do I get the "safe to remove hardware" message in a bub Vista General
Safe Removal of Hardware Vista hardware & devices
No "Safe to remove hardware" Vista General
