Vista - Problems with mounted cd images
Old 06-02-2007   #1 (permalink)
Nate
I am using Vista Ultimate and am having problems copying files from mounted
iso and .bin .cue files. Is this some sort of copy write protection?
Old 06-02-2007   #2 (permalink)
Jane C
Re: Problems with mounted cd images
Where are you trying to copy the files to? Do you get any error messages?
Are you using copy/paste or drag and drop?
Jane, not plain 64 bit enabled :-)
Batteries not included. Braincell on vacation ;-)
MVP Windows Shell/User
"Nate" <Nate@discussions.microsoft.com> wrote in message
news:CDAE9677-2D39-4639-AA64-3205FF413605@microsoft.com...
Old 06-03-2007   #3 (permalink)
Windows Vista™ Ultimate
use daemon tools it works 100% on vista
Old 06-04-2007   #4 (permalink)
Nate
I've tried copying it to me desktop, my C: drive, another data drive and to a
network resource.
Old 06-04-2007   #5 (permalink)
Nate
I'm experiencing this issue while using the latest version of Daemon tools.
This issue is also present with Virtual CD.
> dmex
Old 06-04-2007   #6 (permalink)
Try WinRAR I also use it and it works extracting cd/dvd images or there is PowerISO, MagicISO and WinISO. I cant remember the name for a tool that is used to recover images, it works really well extracting files or folders from any type of media...Just give WinRAR or PowerISO a try wither of these should be able to mount/extract any files. It could be the image you have is corrupted too.
Problems with images and programs Vista General
Sharing Mounted Drive Vista networking & sharing
Installing using mounted iso Vista General
Can you install from a mounted drive?? Vista installation & setup
