Vista - Intellimouse Explorer 4.0 wheel double-click doesn't work
Old 06-03-2007   #1 (permalink)
Larry Sabo
I have the lastest driver installed (6.0.6000.16386) says Device
Manager after checking the web for a later version) but the wheel will
not perform a double-click. Worked fine in Win2k. Now using Vista Home
Basic on a Dell E520, 3.0GHz Celeron. Tried different USB port--no
change.
I suppose this is one of many drivers that need updating by MS?
Anybody got it to work yet?
Larry
Old 06-03-2007   #2 (permalink)
Peter Foldes
Re: Intellimouse Explorer 4.0 wheel double-click doesn't work
Checked your Folder Options\General Tab to see if single click is set
Peter
Please Reply to Newsgroup for the benefit of others
Requests for assistance by email can not and will not be acknowledged.
"Larry Sabo" <larry_sabo@hotmail.com> wrote in message news:lpe563t9p5kovafn5v8cmtss6da80nvuu1@4ax.com...
> change.
> Larry
Old 06-03-2007   #3 (permalink)
Larry Sabo
[Top posting corrected]
> change.
> Larry
Thanks for the suggestion Peter, but the problem is with using the
intellimouse wheel to cause a double-click, not with opening shortcuts
with a sigle left click, which is what the Folder Options\General tab
refers to.
Anyone else?
Larry
Old 06-03-2007   #4 (permalink)
Peter Foldes
{bottom posting corrected}
Sorry Larry I did misread it and you are right. Try and install an earlier driver like IM5 and up
Peter
"Larry Sabo" <larry_sabo@hotmail.com> wrote in message news:gli663pclprki6958r9qndi9cjmn11dhgs@4ax.com...
>> change.
>> Larry
> refers to.
> Anyone else?
> Larry
Old 06-03-2007   #5 (permalink)
Larry Sabo
Hahaha re {bottom posting corrected}. Top posting truncates the text I
was trying to quote, since it follows the "-- " that begins your sig.
That's why I converted it to bottom posting. Anyway, I'll try your
suggestion and post my success/failure.
Cheers,
Larry
Wireless IntelliMouse Explorer with Fingerprint Reader will not work, please help! Vista hardware & devices
Logitech Wheel Mouse Double-Click Vista hardware & devices
Intellimouse Explorer 4.0 Scroll Wheel not working Vista General
Intellimouse Explorer 4.0 Scroll Wheel not working! Vista General
Intellimouse Explorer 4 Scroll Wheel not working Vista General
