| | Resource Monitor - CPU graph In the resource monitor, CPU graph, there is a blue line and green graph. As far as I can tell the blue line is the CPU's clock speed, and the green is the actual utilization. Is that correct? Did I miss any documentation here? -- If quitters never win, and winners never quit, what fool came up with, "Quit while you're ahead"? |
| | Re: Resource Monitor - CPU graph Label Description Memory The Memory label displays the current Hard Faults per second in green and the percentage of physical memory currently in use in blue. -- Regards, Richard Urban Microsoft MVP Windows Shell/User (For email, remove the obvious from my address) Quote from George Ankner: If you knew as much as you think you know, You would realize that you don't know what you thought you knew! "DevilsPGD" <spam_narf_spam@crazyhat.net> wrote in message news:ijg8639g5bss5m8g0cd4qqpvt23heaefgv@4ax.com... > In the resource monitor, CPU graph, there is a blue line and green > graph. > > As far as I can tell the blue line is the CPU's clock speed, and the > green is the actual utilization. Is that correct? > > Did I miss any documentation here? > > -- > If quitters never win, and winners never quit, > what fool came up with, "Quit while you're ahead"? |
| | Re: Resource Monitor - CPU graph In message <#XrSH3spHHA.3264@TK2MSFTNGP04.phx.gbl> "Richard Urban" <richardurbanREMOVETHIS@hotmail.com> wrote: >> In the resource monitor, CPU graph, there is a blue line and green >> graph. >> >> As far as I can tell the blue line is the CPU's clock speed, and the >> green is the actual utilization. Is that correct? > >Label Description >Memory > The Memory label displays the current Hard Faults per second in green and >the percentage of physical memory currently in use in blue. I was referring specifically to the CPU graph, not the memory graph. However, I found it; |The CPU label displays the total percentage of CPU capacity currently in use in green, and the CPU Maximum Frequency in blue. | | Some laptop computers will reduce the Maximum Frequency of the CPU when the computer is not connected to an AC power supply to reduce battery usage. -- If quitters never win, and winners never quit, what fool came up with, "Quit while you're ahead"? |
| Can't open Resource monitor | General Discussion | |||
| Resource Monitor | Tutorials | |||
| Resource Monitor question... | Vista performance & maintenance | |||
| Resource Monitor - CPU graph | Vista performance & maintenance | |||
| resource monitor | Vista General | |||
