General System Performance Questions/Issues
  1. #1
    John C Harris Guest
    I have a DeLL XPS Pentium 1.83 Gig with 2 Gig RAM and ATI Radeon 256 MB
    card.
    Initially had XP Home on it and upgraded to VISTA Home Premium.
    Have generally had few issues but lately my system has been peaking out and
    hanging for about two minutes intermittently. I have turned off Indexing,
    thinking it was that, but no help. It usually happens when opening email in
    Outlook 2007 or while browsing using IE 7.
    I have tried to make notes on when it hangs but there seems to be no rhyme
    of reason to it. I have enough RAM and a big enough Video Card so I am at a
    loss about what is happening. Has any seen this and are there any ideas you
    could offer? I have also checked the performance meter and tracking but it
    is showing no issues.
    Thanks in Advance
    - John
  2. #2
    Kerry Brown Guest
    Re: General System Performance Questions/Issues
    In the Start Search box type Performance, and double click on Performance
    Information and Tools in the results list. Click on Advanced Tools. Work
    through the tools to see what is causing the poor performance.
    Kerry Brown
    Microsoft MVP - Shell/User
    http://www.vistahelp.ca
    "John C Harris" <harris1113@tampabay.rr.com> wrote in message
    news:F8E47195-A0EE-49EB-BFFA-B2A14A6D4979@microsoft.com...
    >card.
    > and hanging for about two minutes intermittently. I have turned off
    > Indexing, thinking it was that, but no help. It usually happens when
    > opening email in Outlook 2007 or while browsing using IE 7.
    > a loss about what is happening. Has any seen this and are there any ideas
    > you could offer? I have also checked the performance meter and tracking
    > but it is showing no issues.
    > Thanks in Advance
    > - John
  3. #3
    Wayne L. Guest
    At 180 GBs you're on the low side. As a start, go in Control Panel to
    "Performance Information and Tools" and check " Base Score". My Vista with
    236 GBs scores at a paultry 2.0 - totally inadequite for Aero (for example).
    Then click computer and check HD usage. System Restore will use about 27 GBs
    (15% of total 180) and this has caused problems for some. Mine was up to 35
    GBs but I got it down to 10. Don't disable SR as you will most likely need
    it. Wayne
    Wayne L.
    > Kerry Brown
    > >card.
    > > Thanks in Advance
    > > - John
  4. #4
    John Barnes Guest
    I agree. When I had a 3500+ I was also having hangs, etc. after upgrading
    to a 5200+ x2 these were mostly gone. To get rid of the rest of the
    problem I had to manually set the affinity of several running processes to
    one of the cpu's. Using the performance tools as suggested by Kerry should
    help you identify your problem.
    "Wayne L." <WayneL@discussions.microsoft.com> wrote in message
    news:4E8727FC-D831-44E0-A1F1-604A69BF7BD8@microsoft.com...
    > example).
    > GBs
    > 35
    > it. Wayne
    > Wayne L.
    >> Kerry Brown
    >> >card.
    >> > rhyme
    >> > at
    >> > ideas
    >> > Thanks in Advance
    >> > - John
  5. #5
    John C Harris Guest
    My base score is a 4.2 so I SHOULD be good. Went into the performance and
    the only thing that hinted at a problem was a shell error at one point when
    I KNOW it was hanging, but there is nothing there as how to resolve it. Just
    to be certain I went ahead and disabled the aero stuff and watching it now
    to see what happens.
    The "180 Gigs you are referring to sounds like Hard Drive size. I was
    referring to my processor.
    > example).
    > GBs
    > 35
    > it. Wayne
    > Wayne L.
    >> Kerry Brown
    >> >card.
    >> > rhyme
    >> > at
    >> > ideas
    >> > Thanks in Advance
    >> > - John
  6. #6
    John C Harris Guest
    Do you think I need to upgrade my processor? How/where do I find what my
    system can handle? Would DeLL possibly know?
    I am thinking this is what I need to do but never done that before so need
    to be careful
    "John Barnes" <jbarnes@email.net> wrote in message
    news:erzzhj3pHHA.4496@TK2MSFTNGP06.phx.gbl...
    >> with
    >> example).
    >> GBs
    >> 35
    >> need
    >> it. Wayne
    >> Wayne L.
    >>> Performance
    >>> Kerry Brown
    >>> >card.
    >>> > out
    >>> > rhyme
    >>> > at
    >>> > ideas
    >>> > tracking
    >>> > Thanks in Advance
    >>> > - John
  7. #7
    Kerry Brown Guest
    newsDC9A61B-E24F-486E-B89B-50B71FC861D5@microsoft.com...
    > when I KNOW it was hanging, but there is nothing there as how to resolve
    > it. Just to be certain I went ahead and disabled the aero stuff and
    > watching it now to see what happens.
    Did you click on "View Performance details in Event log"? Go through the log
    and look for Event ID's in the 400's and 500's.
    Kerry Brown
General System Performance Questions/Issues problems?
General vista/XP questions lsc Vista General 2 15 Sep 2009
General Questions CJ Hames Vista installation & setup 1 08 Jul 2008
General questions LP Vista hardware & devices 1 04 Jul 2008
General performance issues Arne-Kolja Bachstein Vista performance & maintenance 2 21 Jun 2007
A few questions in general =?Utf-8?B?R2I3NTVj?= Vista General 7 19 Sep 2006
