Vista - Right Click Context Menu Help
Old 06-06-2007   #1 (permalink)
Steve Drury
Hi all,
I have just installed, vista 64-bit and am loving it at the minute.
I only have a few small niggles. I have installed 2 programs that I used to
use in Windows XP: imgBurn & Norton Antivirus (installed internet security
2007 with vista 64 upgrade).
With Norton AV I used to be able to right click a folder in XP and select
scan for viruses. This is no longer an option in the right click context
menu in vista. Any ideas how I can get this back?
Also I have a similar problem with imgBurn - I used to be able to right
click an .iso image and select burn with imgburn but this is no longer there
either.
If I could get this back that would be perfect, especially the antivirus
right click.
Any ideas?
Thanks,
Steve
Old 06-06-2007   #2 (permalink)
Charles W Davis
Re: Right Click Context Menu Help
Dump the Norton Antivirus. Known problem on Vista. Suggest the free AVG
Anti-virus. http://free.grisoft.com
AVG automatically updates and scans the computer on your schedule. You can
also manually start the check for updates and scan.
"Steve Drury" <Steve Drury@discussions.microsoft.com> wrote in message
news:B12C3646-76BA-4AB1-8D42-169F26462D3B@microsoft.com...
> Hi all,
> to
> there
> either.
> right click.
> Any ideas?
> Thanks,
> Steve
Right click context menu Vista General
context menu/right click Vista performance & maintenance
Context Menu Appears without right click Vista performance & maintenance
Loosing right click context menu in every application ... Vista file management
