| | This problem was caused by Ati2evxx.exe Help anyone? Hi. I have a problem with my new computer: Every time when I startup the machine I get this message: Problem caused by Ati2evxx.exe (Use System Configuration Utility to prevent this from running at startup) This problem was caused by Ati2evxx.exe (Use System Configuration Utility to prevent this from running at startup). This program was created by ATI Technologies, Inc.. ATI Technologies, Inc. does not currently have a solution for the problem that you reported. I can´t quite figure out how to prevent this program from running. Could anyone guide me through this task step by step? Thank you in advance! |
| | Re: This problem was caused by Ati2evxx.exe Help anyone? What MS is advising is that you run the program msconfig as an administrator and prevent the startup of the named program. (Windows Key/R, type in msconfig, OK, continue, click on startup tab, in the startup item column there should be an entry for Ati2evxx.exe. Unselect (remove tick mark) from that entry. When you restart, that program will no longer be automatically started. That may get rid of the error message but you probably actually need to update the video drivers for your ATI card. Do that by going to the ATI web site and checking for updated drivers. Note that updating ATI drivers is not always a easy thing. If you are not having additional problems with your system and the above gets rid the nagging error you might just leave well enough alone. Michael "Silmarwen" <Silmarwen@discussions.microsoft.com> wrote in message news:F97A3B4A-56A0-4B46-919A-1B68943ECAF2@microsoft.com... > Hi. > > I have a problem with my new computer: Every time when I startup the > machine > I get this message: > > Problem caused by Ati2evxx.exe (Use System Configuration Utility to > prevent > this from running at startup) > > This problem was caused by Ati2evxx.exe (Use System Configuration Utility > to > prevent this from running at startup). This program was created by ATI > Technologies, Inc.. ATI Technologies, Inc. does not currently have a > solution > for the problem that you reported. > > > I can´t quite figure out how to prevent this program from running. Could > anyone guide me through this task step by step? > > Thank you in advance! |
| This problem was caused by Bitdefender Antivirus | System Security | |||
| Problem caused by Bitdefender Antivirus | Vista security | |||
| Problema provocado por Ati2evxx.exe (Use System Configuration Util | Vista General | |||
| a problem caused the program to stop | Vista General | |||
