| | Vista - Indexing is not running?? |
| 06-08-2007 | #1 |
| | Indexing is not running?? I must have turned it off somehow but that's what I see when I bring up the indeing options box. So I do a search in "HELP" for turn on indexing and it says: Can I turn the Windows search index on or off? No, the index can't be turned off or paused. heh heh Is there a way I can fix my non indexing Vista Home Prem.? The only buttons that I have that work on the indexing options screen is the CLOSE button, the Modify and Advanced buttons are greyed out. Thank You for any help! Bob |
| My System Specs |
| 06-08-2007 | #2 |
| | Re: Indexing is not running?? Just something to check, in the Programs and Features control panel, in the Turn Windows Features On/Off sub-panel, mine shows "Indexing Service" as not checked, but indexing seems to be working. You might check that in yours. It actually was something I was going to look into, whether this feature is "the" indexing or something extra, why it wouldn't be on by default, etc. Tom On Jun 8, 9:12 pm, Bob <bobar...@wildblue.net> wrote: > I must have turned it off somehow but that's what I see when I bring up > the indeing options box. So I do a search in "HELP" for turn on indexing > and it says: > > Can I turn the Windows search index on or off? > > No, the index can't be turned off or paused. > > heh heh > > Is there a way I can fix my non indexing Vista Home Prem.? The only > buttons that I have that work on the indexing options screen is the > CLOSE button, the Modify and Advanced buttons are greyed out. Thank You > for any help! > > Bob |
| My System Specs |
| 06-09-2007 | #3 |
| | Re: Indexing is not running?? Read the description it gives you in the "Turn Windows Features On/Off" by placing the mouse over it (tooltip): "File indexing service that shipped in versions prior to Windows Vista. Provided as an optional feature for backwards compatibility only." Robert Firth http://www.winvistainfo.org "njem" <njemtcan-njem@yahoo.com> wrote in message news:1181363042.225143.224610@j4g2000prf.googlegroups.com... > Just something to check, in the Programs and Features control panel, > in the Turn Windows Features On/Off sub-panel, mine shows "Indexing > Service" as not checked, but indexing seems to be working. You might > check that in yours. It actually was something I was going to look > into, whether this feature is "the" indexing or something extra, why > it wouldn't be on by default, etc. > > Tom > > > On Jun 8, 9:12 pm, Bob <bobar...@wildblue.net> wrote: >> I must have turned it off somehow but that's what I see when I bring up >> the indeing options box. So I do a search in "HELP" for turn on indexing >> and it says: >> >> Can I turn the Windows search index on or off? >> >> No, the index can't be turned off or paused. >> >> heh heh >> >> Is there a way I can fix my non indexing Vista Home Prem.? The only >> buttons that I have that work on the indexing options screen is the >> CLOSE button, the Modify and Advanced buttons are greyed out. Thank You >> for any help! >> >> Bob > > |
| My System Specs |
| 06-09-2007 | #4 |
| | Re: Indexing is not running?? I checked it and it didn't do anything, it's for prior releases or something. Still not indexing anyway. Thank you though, thought maybe you'd found the answer! ;o) Bob njem wrote: > Just something to check, in the Programs and Features control panel, > in the Turn Windows Features On/Off sub-panel, mine shows "Indexing > Service" as not checked, but indexing seems to be working. You might > check that in yours. It actually was something I was going to look > into, whether this feature is "the" indexing or something extra, why > it wouldn't be on by default, etc. > > Tom > > > On Jun 8, 9:12 pm, Bob <bobar...@wildblue.net> wrote: >> I must have turned it off somehow but that's what I see when I bring up >> the indeing options box. So I do a search in "HELP" for turn on indexing >> and it says: >> >> Can I turn the Windows search index on or off? >> >> No, the index can't be turned off or paused. >> >> heh heh >> >> Is there a way I can fix my non indexing Vista Home Prem.? The only >> buttons that I have that work on the indexing options screen is the >> CLOSE button, the Modify and Advanced buttons are greyed out. Thank You >> for any help! >> >> Bob > > |
| My System Specs |
| 06-09-2007 | #5 |
| | Re: Indexing is not running?? Yep, you got it right. Didn't do squat for my "not indexing" problem. Any ideas on a fix? If it can't be turned on or off how in the world did I turn it off? Bob Robert Firth wrote: > Read the description it gives you in the "Turn Windows Features On/Off" > by placing the mouse over it (tooltip): > > "File indexing service that shipped in versions prior to Windows Vista. > Provided as an optional feature for backwards compatibility only." > > Robert Firth > http://www.winvistainfo.org > > " |
| My System Specs |
| 06-09-2007 | #6 |
| | Re: Indexing is not running?? Tooltip. Oh. Too both obvious and subtle. I missed it. On Jun 8, 10:33 pm, "Robert Firth" <webmas...@winvistainfo.org> wrote: > Read the description it gives you in the "Turn Windows Features On/Off" by > placing the mouse over it (tooltip): > > "File indexing service that shipped in versions prior to Windows Vista. > Provided as an optional feature for backwards compatibility only." > |
| My System Specs |
| 06-09-2007 | #7 |
| | Re: Indexing is not running?? "Bob" <bobarnes@wildblue.net> wrote in message news:eChqGykqHHA.4180@TK2MSFTNGP04.phx.gbl... >I must have turned it off somehow but that's what I see when I bring up the >indeing options box. So I do a search in "HELP" for turn on indexing and it >says: > > Can I turn the Windows search index on or off? > > No, the index can't be turned off or paused. > > > heh heh > > Is there a way I can fix my non indexing Vista Home Prem.? The only > buttons that I have that work on the indexing options screen is the CLOSE > button, the Modify and Advanced buttons are greyed out. Thank You for any > help! > > Bob Start the 'Windows Search service via Start > services.msc [ Actually it is possible to pause it, but not via the gui which is perhaps what was meant. ] -- Jon |
| My System Specs |
| 06-10-2007 | #8 |
| | Re: Indexing is not running?? That did it Jon, Thank You very much. Bob Jon wrote: > "Bob" <bobarnes@wildblue.net> wrote in message > news:eChqGykqHHA.4180@TK2MSFTNGP04.phx.gbl... >> I must have turned it off somehow but that's what I see when I bring >> up the indeing options box. So I do a search in "HELP" for turn on >> indexing and it says: >> >> Can I turn the Windows search index on or off? >> >> No, the index can't be turned off or paused. >> >> >> heh heh >> >> Is there a way I can fix my non indexing Vista Home Prem.? The only >> buttons that I have that work on the indexing options screen is the >> CLOSE button, the Modify and Advanced buttons are greyed out. Thank >> You for any help! >> >> Bob > > > Start the 'Windows Search service via > > Start > services.msc > > [ Actually it is possible to pause it, but not via the gui which is > perhaps what was meant. ] > > |
| My System Specs |
| Similar Threads for: Indexing is not running?? | ||||
| Indexing is not running pop up | Vista performance & maintenance | |||
| Folders do not display in Indexing Options / Indexing Locations | Vista file management | |||
| Indexing service isn't indexing a particular file under documents. | Vista file management | |||
| Indexing is not running | Vista General | |||
| Is indexing running at the moment? | Vista General | |||
