Vista - How to change Vista Premium Startup sound
Old 06-09-2007   #1 (permalink)
goingforward
How do you go about changing the startup sound in windows vista? It's
blocked by default and I can't change it to a different wav file like I could
with windows xp. I want to use a different startup sound and am logged in as
administrator but I don't even have the option to browse to find a wav file
to use. Can anyone help? Thanks.
Old 06-09-2007   #2 (permalink)
Robert Firth
Re: How to change Vista Premium Startup sound
You need a resource editor like resource hacker:
http://www.angusj.com/resourcehacker/
I think the sound is in c:\windows\system32\imageres.dll, but I might have
forgotten exactly which one it is in. I don't know if it can be replaced,
but it can be extracted...
Robert Firth
http://www.winvistainfo.org
"goingforward" <goingforward@discussions.microsoft.com> wrote in message
news:20100E4C-5BE3-4397-B600-0F78E083BCCA@microsoft.com...
> could
> as
> file
Old 06-09-2007   #3 (permalink)
Tiberius
yeah thats another stupid thing about vista
"Robert Firth" <webmaster@winvistainfo.org> wrote in message
news:98DBDD80-605F-4490-BE41-5FB3CA246E80@microsoft.com...
> Robert Firth
>> could
>> in as
>> file
Old 06-09-2007   #4 (permalink)
Fats
I just changed the sound and didn't seem to have any problems (although I
usually keep it off). One thing, I think the event for the startup sound is
call "Windows
Login". I went to CP.....Hardware and Sound....Change System
Sounds...Selected Windows Logon (which enabled the Test and Browse
features), and selected a wav.
"Tiberius" <321@123.32> wrote in message
news:%23qUV%23mmqHHA.4420@TK2MSFTNGP04.phx.gbl...
>> have forgotten exactly which one it is in. I don't know if it can be
>> replaced, but it can be extracted...
>> Robert Firth
>>> could
>>> in as
>>> file
Old 06-09-2007   #5 (permalink)
Tiberius
That is the windows login sound.. not the startup sound
in vista the startup sound is hardcoded inside a dll
Why did they decide to hardcode a sound is a mystery to me...
there was a whole outcry from people when MS had the sound
so it could not be turned off.. after protest they added a checkbox so you
can disable it
"Fats" <Vegas@Nevada> wrote in message
news:O0VmVEnqHHA.4104@TK2MSFTNGP06.phx.gbl...
>call "Windows
>>> Robert Firth
>>>> could
>>>> in as
>>>> file
Old 06-09-2007   #6 (permalink)
Fats
Thanks for the info...wonder why they did that? (hardcoded in a dll)
Were they trying to come up with an MS theme song or something?
So many weird things in Vista.....
news:ex6OUInqHHA.3492@TK2MSFTNGP02.phx.gbl...
> can disable it
>>is call "Windows
>>>> Robert Firth
>>>> message news:20100E4C-5BE3-4397-B600-0F78E083BCCA@microsoft.com...
>>>>> I could
>>>>> logged in as
>>>>> file
Old 06-09-2007   #7 (permalink)
Rick Rogers
Why?
It's called branding, a sound trademark. Like many other device startup
sounds and visuals, its not meant to be changed, it's meant to develop an
association between the consumer and the product.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
news:uClDXOnqHHA.4520@TK2MSFTNGP04.phx.gbl...
>> you can disable it
>>>is call "Windows
>>>>> Robert Firth
>>>>>> It's
>>>>>> I could
>>>>>> logged in as
>>>>>> wav file
Old 06-09-2007   #8 (permalink)
Tiberius
CRAP!!!!
That's exactly why people like computers! because they are ultimatily
customizable!!!
If we wanted a toaster with a bell ringer to signify when the toast is done,
we would buy it!
Gesh....
"Rick Rogers" <rick@mvps.org> wrote in message
news:uzsoBJoqHHA.4624@TK2MSFTNGP06.phx.gbl...
> Why?
> Best of Luck,
>>> you can disable it
>>>>I usually keep it off). One thing, I think the event for the startup
>>>>sound is call "Windows
>>>>>> Robert Firth
>>>>>>> It's
>>>>>>> like I could
>>>>>>> logged in as
>>>>>>> wav file
Old 06-09-2007   #9 (permalink)
Jupiter Jones [MVP]
There are usually limits to customization with any software.
"ultimatily customizable" if you mean anything and everything can be
customized is not correct.
If you dislike this so much, have you expressed your opinion to
Microsoft?
Jupiter Jones [MVP]
http://www3.telus.net/dandemar
http://www.dts-l.org
news:OOmqKapqHHA.532@TK2MSFTNGP06.phx.gbl...
> CRAP!!!!
> ultimatily customizable!!!
> is done,
> we would buy it!
> Gesh....
Old 06-09-2007   #10 (permalink)
goingforward
So it looks like I'm stuck with the startup sound unless microsoft releases
some sort of patch to allow an end user the ability to change it. The
branding makes sense but I still should be able to change it if I want to, no
fair!! Thanks everyone for the information.
> Microsoft?
> Jupiter Jones [MVP]
> > CRAP!!!!
> > is done,
> > we would buy it!
> > Gesh....
vista startup sound Sound & Audio
VISTA: How to change the order in which programs launch on startup Vista General
Windows Vista Startup Sound Vista General
you cant change the friken startup sound in vista Vista General
Vista Startup sound missing Vista General
