Vista - WMDC 6.1 Still Does Not Work
Old 06-10-2007   #1 (permalink)
RickB
I am furiously angry. I have a Motorla Q that synced just fine with XP. I
just wasted $2300 getting a Sony VISTA laptop that WILL NOT SYNC no matter
what. Turned off anti-virus, turned off firewall, opened individual ports,
more and more and more! I was told "don't worry, Microsoft hears you! They
will put out an upgrade to WMDC in a few weeks guaranteed to fix your
problem." Well, the "upgrade (6.1) does not work! Now I have a $500
smartphone that cannot talk to a $2300 laptop. I am angry, I feel totally
lied to and screwed over. For the first time in my life I feel like saying
screw you Microsoft!
I am sorry for the rant, buy why, why, why does it have to be so hard when
it worked before?
Apologies, RickB
Old 06-10-2007   #2 (permalink)
Tiberius
Re: WMDC 6.1 Still Does Not Work
Hello how do these 2 devices communicate? via IR, bluetooth,
or some cable (like USB)
if its USB then I would suggest you install vmware, install XP inside it,
and use a USB port to communicate the phone via XP...
until or if ever a solution is found for vista..
if you do have usb and you need help to do the above post back
Old 06-10-2007   #3 (permalink)
R. McCarty
Which Wireless provider is the "Q" phone from ? I've hooked up more
than a few Q phones/Palm Treos to Vista machines and all have worked
with WMDC ( including the recent 6.1 update ).
One thing you have to avoid is installing ANY version of ActiveSync on
a Vista machine. Have you checked the Event Logs for any clues to why
the Q won't sync. Also, Smartphones tend to use the full 500mA current
draw on a USB port. You have to be careful not to overload either the
power/bandwidth limitations of the USB channels.
"RickB" <RickB@discussions.microsoft.com> wrote in message
news:F844B591-765B-437C-A43C-DAB394EA08AA@microsoft.com...
> ports,
> They
> saying
> it worked before?
> Apologies, RickB
WMDC Vista mail
I Give Up on WMDC and Active Sync--Any 3rd Party Apps That Work? Vista General
WMDC Vista General
WMDC Vista General
WMDC Vista hardware & devices
