| | Need Help with Scanner, was working!! I have a Epson CX7800 all in one and when I originally got my new computer, HP1730n w/Vista I had trouble installing due to compatibility. I can't remember what I did (I think install drivers from Epson) but both the scanner and printer worked for the last few months. Now all of a sudden the scanner is not working , error reads:Epson scanner cannot be started.' When I right click on Epson settings it reads under scanner status: Scanner is not ready. Interface: Not Connected Option:Unknown. I've checked and checked connections, wrote Epson and uninstalled and installed three times, all times it says that driver installed correctly. Printer works just fine. I installed just the way I was told. I don't know how it can happen when nothings changed. Can updates cause a problem? I'm not exactly sure what Interface means in that error msg. I feel I'm banging my head against the same wall. Any other options out there would be appreciated. Thanks Mo4 |
| | Re: Need Help with Scanner, was working!! See if any of the links here help http://www.google.co.uk/search?hl=en...ot+ready&meta= "Mo4" <Mo4.2s01q2@no-mx.forums.net> wrote in message news:Mo4.2s01q2@no-mx.forums.net... > > I have a Epson CX7800 all in one and when I originally got my new > computer, HP1730n w/Vista I had trouble installing due to compatibility. > I can't remember what I did (I think install drivers from Epson) but > both the scanner and printer worked for the last few months. Now all of > a sudden the scanner is not working , error reads:Epson scanner cannot > be started.' When I right click on Epson settings it reads under scanner > status: Scanner is not ready. Interface: Not Connected Option:Unknown. > I've checked and checked connections, wrote Epson and uninstalled and > installed three times, all times it says that driver installed > correctly. Printer works just fine. I installed just the way I was told. > I don't know how it can happen when nothings changed. Can updates cause > a problem? I'm not exactly sure what Interface means in that error msg. > I feel I'm banging my head against the same wall. Any other options out > there would be appreciated. Thanks Mo4 > > > -- > Mo4 |
| | Re: Need Help with Scanner, was working!! I read the links and unfortunatly it still didn't help. It does talk about registry cleaning but thats a little over my head. I did go and try a file search and delete all epson files before I once again tried to uninstall and reinstall, although some said they couldn't be found. I appreciate the help though. Thank Mo4 |
| 32 Bit Scanner has stopped working | Vista General | |||
| Scanner stopped working | Vista print fax & scan | |||
| Epson scanner not working | Vista hardware & devices | |||
| Scanner not working with Vista | Vista mail | |||
| Cant get scanner working correctly | Vista print fax & scan | |||
