Vista - Font problem
Old 06-11-2007   #1 (permalink)
Piotrek
Font problem
I have Vista Bussiness and have strange problem with greek font. I work with
greek texts and greek font is essential in my work. I have been using
Windows XP for many years and there were never any problems with fonts.
After completely fresh Vista setup I copied my font and there is strange
problem with Greek font. When I open Character Map and choose Greek font,
there is no character with code 009D. There is such character in the font
file - the same works with XP and 2000 without any problems. I tried my
Vista Bussiness and Ultimate on other machine - the same problem occurs. The
font is free so I put it for geeks. Maybe there is some way to make it work
under Vista ? I check the 009D sign, but maybe others are missing too.
Link to font file:
http://rapidshare.com/files/36510241/GREEK__2.TTF.html
Thaks for your help,
Peter
Font problem General Discussion
Font Problem Vista mail
Font problem Vista General
Font Problem!! Vista file management
Font Problem!! Vista General
Designer Media Ltd
