| | Print Spooler Lock up After first Print Using Windows Vista, most (75%) laptops lock up the print spooler after the first print. I am using a networked (TCP\IP) OKIDATA 5100C printer. Of course, the driver is written for windows XP since OKI hasnt created a vista driver. I see other people experiencing the same problem with other brand name printers. I am hoping for a fix in VISTA... any IDEAS? Thanks |
| Print Spooler | Vista General | |||
| HOw do I start the print spooler so I can install my print drivers? | Vista installation & setup | |||
| Print Spooler hangs and doesn't print | Vista print fax & scan | |||
| print spooler | Vista print fax & scan | |||
| Print Spooler Locks up After first Print | Vista hardware & devices | |||
