Vista - How to "REPAIR" a wireless connection
Old 06-12-2007   #1 (permalink)
Ike
Vista Home Premium, Core Duo
In XP and 98 I could click on the ONLINE icon in the
notification portion of the tray, select REPAIR, and solve
certain wireless problems.
I don't see such an icon in Vista, and if there's a REPAIR
function I don't know how to access it. I did
PROPERTIES>NOTIFICATION>CUSTOMIZE, etc. and there is no option
to see such an icon.
On the other hand, it's great that in six weeks of Vista I
haven't had a connectivity problem... in XP it happened
frequently. But today I lost the net and the only way I found to
get back on was a reboot. Surely there's a REPAIR function
somewhere...
Ike
Old 06-12-2007   #2 (permalink)
Michael Solomon
Re: How to "REPAIR" a wireless connection
"Ike" <binarydotike@gmail.com> wrote in message
news:f4mos9$k0k$1@registered.motzarella.org...
> In XP and 98 I could click on the ONLINE icon in the notification portion
> of the tray, select REPAIR, and solve certain wireless problems.
> I don't see such an icon in Vista, and if there's a REPAIR function I
> don't know how to access it. I did PROPERTIES>NOTIFICATION>CUSTOMIZE, etc.
> and there is no option to see such an icon.
> On the other hand, it's great that in six weeks of Vista I haven't had a
> connectivity problem... in XP it happened frequently. But today I lost the
> net and the only way I found to get back on was a reboot. Surely there's a
> REPAIR function somewhere...
> Ike
I don't know why the Network icon is not being displayed in the notification
area, I suspect it may be a driver issue related to your network card.
However, you can repair as follows and the only thing the Network icon would
provide you is a link to open this dialog. Go to Control Panel and select
"Network and Sharing" center. In the left column, the "Tasks" list, click
"Diagnose and repair."
In Vista, the network icon should appear by default in the notification
area. In a Google search, I did find others who have the same problem but
in my preliminary check, I've not found a cause or a solution beyond rolling
back to a time when it did appear. Since, in your case, it seems it never
was there, that's not possible for you but based on the random nature of
this issue, it does seem to be a driver issue. You might want to check to
be sure you have the latest drivers for your network card.
Michael Solomon
Backup is a PC user's best friend
DTS-L.Org: http://www.dts-l.org/
Old 06-12-2007   #3 (permalink)
Ike
>> portion of the tray, select REPAIR, and solve certain wireless problems.
>> etc. and there is no option to see such an icon.
>> a connectivity problem... in XP it happened frequently. But today I
>> lost the net and the only way I found to get back on was a reboot.
>> Surely there's a REPAIR function somewhere...
>> Ike
> notification area, I suspect it may be a driver issue related to your
> network card. However, you can repair as follows and the only thing the
> Network icon would provide you is a link to open this dialog. Go to
> Control Panel and select "Network and Sharing" center. In the left
> column, the "Tasks" list, click "Diagnose and repair."
> but in my preliminary check, I've not found a cause or a solution beyond
> rolling back to a time when it did appear. Since, in your case, it
> seems it never was there, that's not possible for you but based on the
> random nature of this issue, it does seem to be a driver issue. You
> might want to check to be sure you have the latest drivers for your
> network card.
This worked perfectly - thanks! However, a minute later the
problem arose again, which leads me to suspect that it is not
Vista-related. It's a new Dell laptop, so I will call them for
some hardware diagnostics.
With gratitude...
Old 06-12-2007   #4 (permalink)
Michael Solomon
news:f4mt7j$1mk$1@registered.motzarella.org...
>>> the net and the only way I found to get back on was a reboot. Surely
>>> Ike
>> rolling back to a time when it did appear. Since, in your case, it seems
>> it never was there, that's not possible for you but based on the random
>> nature of this issue, it does seem to be a driver issue. You might want
>> to check to be sure you have the latest drivers for your network card.
> This worked perfectly - thanks! However, a minute later the problem arose
> again, which leads me to suspect that it is not Vista-related. It's a new
> Dell laptop, so I will call them for some hardware diagnostics.
> With gratitude...
You're welcome, good luck.
Michael Solomon
"Wireless Networks Are Available", but my "Connect To" list is emp Vista networking & sharing
How to use "change" & "repair" under Features Vista performance & maintenance
No Wireless connection in "Scanners and Cameras" Vista print fax & scan
"Intel(R) PRO/Wireless 3945ABG Network Connection" driver installa Vista hardware & devices
How to "repair wireless connection" without waiting in Vista Vista networking & sharing
