| | Active X Control not working? Tried everything on Adobe Support and yet having problems watching videos from YouTube and other sites. Any assistance will be greatly appreciated. Thanks. |
| | Re: Active X Control not working? What version of Vista? If business or above, install the ActiveX installer service and then set it as enabled and automatic. Add or Remove Programs > Windows Components. ( or the vista equivalent ) I'm not in Vista at the moment. -- Steve Easton "Omega_man" <Omegaman@discussions.microsoft.com> wrote in message news E436AB9-1512-40CE-B4F0-448481849FB4@microsoft.com...> Tried everything on Adobe Support and yet having problems watching videos > from YouTube and other sites. > > Any assistance will be greatly appreciated. > > Thanks. |
| | Re: Active X Control not working? "Steve Easton" wrote > What version of Vista? > If business or above, install the ActiveX installer service and then set > it as enabled and automatic. > Add or Remove Programs > Windows Components. ( or the vista equivalent ) > I'm not in Vista at the moment. Control Panel | Programs | Turn Windows Features On and Off | ActiveX Installer Service. -- Rock [MS-MVP User/Shell] |
| | Re: Active X Control not working? I am using Vista Home Premiun. I followed the steps, I do not have "ActiveX Installer Service" on the list of Windows Features On and Off. I uninstalled Flash Player and reinstalled again, Adobe sites said Successfuly Installed and played the movie. Once, I chaged security setting to default, I started getting the pop up messages "IE has blocked this site from using ActiveX control in an unsafe manner. "Rock" wrote: > "Steve Easton" wrote > > What version of Vista? > > If business or above, install the ActiveX installer service and then set > > it as enabled and automatic. > > Add or Remove Programs > Windows Components. ( or the vista equivalent ) > > I'm not in Vista at the moment. > > Control Panel | Programs | Turn Windows Features On and Off | ActiveX > Installer Service. > > -- > Rock [MS-MVP User/Shell] > > |
| | Re: Active X Control not working? "Omega_man" wrote > I am using Vista Home Premiun. > > I followed the steps, I do not have "ActiveX Installer Service" on the > list > of Windows Features On and Off. > > I uninstalled Flash Player and reinstalled again, Adobe sites said > Successfuly Installed and played the movie. > > Once, I chaged security setting to default, I started getting the pop up > messages "IE has blocked this site from using ActiveX control in an unsafe > manner. > > > "Rock" wrote: > >> "Steve Easton" wrote >> > What version of Vista? >> > If business or above, install the ActiveX installer service and then >> > set >> > it as enabled and automatic. >> > Add or Remove Programs > Windows Components. ( or the vista >> > equivalent ) >> > I'm not in Vista at the moment. >> >> Control Panel | Programs | Turn Windows Features On and Off | ActiveX >> Installer Service. Ok, IE security settings is not my area. Steve might post back with more suggestions. You might want to post to the internet explorer newsgroup as well. http://www.microsoft.com/communities...&lang=en&cr=us -- Rock [MS-MVP User/Shell] |
| | #6 (permalink) |
| | Re: Active X Control not working? "Rock" wrote: > "Omega_man" wrote > > I am using Vista Home Premiun. > > > > I followed the steps, I do not have "ActiveX Installer Service" on the > > list > > of Windows Features On and Off. > > > > I uninstalled Flash Player and reinstalled again, Adobe sites said > > Successfuly Installed and played the movie. > > > > Once, I chaged security setting to default, I started getting the pop up > > messages "IE has blocked this site from using ActiveX control in an unsafe > > manner. > > > > > > "Rock" wrote: > > > >> "Steve Easton" wrote > >> > What version of Vista? > >> > If business or above, install the ActiveX installer service and then > >> > set > >> > it as enabled and automatic. > >> > Add or Remove Programs > Windows Components. ( or the vista > >> > equivalent ) > >> > I'm not in Vista at the moment. > >> > >> Control Panel | Programs | Turn Windows Features On and Off | ActiveX > >> Installer Service. > > Ok, IE security settings is not my area. Steve might post back with more > suggestions. You might want to post to the internet explorer newsgroup as > well. > > http://www.microsoft.com/communities...&lang=en&cr=us > > -- > Rock [MS-MVP User/Shell] > > Thanks guys. |
| | #7 (permalink) |
| | Re: Active X Control not working? "Omega_man" wrote <snip> > Thanks guys. You're welcome. -- Rock [MS-MVP User/Shell] |
| Active X control | Vista installation & setup | |||
| How to Install Active X Control | Vista General | |||
| Active X control | Vista security | |||
| How can I remove Active-X Control? | Vista General | |||
| problem with active x control | Vista General | |||
