| | Vista - Vista Errors and Bugs, Need help with |
| 06-14-2007 | #1 |
| | Vista Errors and Bugs, Need help with Ok i have many errors that my (friends) New Vista computer is having and i need help with them and they include: 1. On startup i get and error that all it says is "???42" and an ok button 2. Something with the fire wall is not starting up so every few seconds i get an erorr of that and then when i click to turn it on it says the security center cant turn it on and then i click turn on manually but then it says The Windows Firewall service isnt on so i press to turn that on and it says it cant start it. 3. I try to turn on the Network Discovery option in the Network and Sharing Center and then it locks up ONLY that window, i let it run for about 5 hours and i can back and it was still there just doing nothing and that window still locked up 4. It wont defrag... nuf' said If ANYONE can help with ANY of these problems, It would be a great help and it would also save a computers life casue My Friend and ai want to shove this thing out the window |
| 06-14-2007 | #2 |
| | Re: Vista Errors and Bugs, Need help with "The Bass Hero" wrote > Ok i have many errors that my (friends) New Vista computer is having and i > need help with them and they include: > > 1. On startup i get and error that all it says is "???42" and an ok button > > 2. Something with the fire wall is not starting up so every few seconds i > get an erorr of that and then when i click to turn it on it says the > security > center cant turn it on and then i click turn on manually but then it says > The > Windows Firewall service isnt on so i press to turn that on and it says it > cant start it. > > 3. I try to turn on the Network Discovery option in the Network and > Sharing > Center and then it locks up ONLY that window, i let it run for about 5 > hours > and i can back and it was still there just doing nothing and that window > still locked up > > 4. It wont defrag... nuf' said > > > If ANYONE can help with ANY of these problems, > It would be a great help and it would also save a computers life casue My > Friend and ai want to shove this thing out the window If it's new and these problems existing right from the beginning use the warranty support from the computer manufacturer. This should not happen with a new system. -- Rock [MS-MVP User/Shell] |
Similar Threads for: Vista Errors and Bugs, Need help with
| Why Does Vista Have So Many Bugs ? | General Discussion | |||
| iTunes & Quicktime Bugs/Errors, Help! | Software | |||
| Vista pro - bugs... bugs... bugs... | Vista performance & maintenance | |||
| Bugs with Vista | Vista General | |||
| Overall Vista Bugs | Vista General | |||
