Vista Tutorial - Vista not sleeping problem---SOLVED
Old 06-14-2007   #1 (permalink)
Harry
Guest
My Dell E521 running Vista Home/ Student Premium has refused to sleep for
longer than 30 seconds. Dell was unable to solve and blamed Microsoft. I've
tried all the published solutions and workarounds with no success. Changed
power management so that only the keyboard would wake the system. My Dell
still remained an insomniac.
I finally unplugged my network cable from my cable modem and voila.. sleep.
Then I found in Device Manager/ Network adapter/advanced, a menu containing
'Wake up capability'. I selected 'None', and that has solved my problem.
The caveat is that I can't run the Photos screensaver or sleep won't come,
even though I have selected to allow sleep while running multimedia. If
someone has this solution, please let me know.
Harry
Attention Vista Freezes Problem Solved! Vista General
How My Windows Vista Mail Problem Was Solved Vista mail
Solved my Vista/XP shared printer problem Vista print fax & scan
VISTA PROBLEM SOLVED>>>>>MUST READ!!! Vista installation & setup
