Vista Tutorial - Dial Up Connection and Broadband
Old 06-15-2007   #1 (permalink)
Kevin Mc
Guest
I can not get Novatel Broadband modem to work. The device manager recognizes
it but I can not setup a dial up connection automatically or manually. Keep
gettng error that modem can't be found.
Vendor software installs correctly but it can not create a dial up
connection either and will not recognize the modem. I have tried both a USB
and a PCMCIA modem.
Old 06-15-2007   #2 (permalink)
Cal Bear '66
Guest
Re: Dial Up Connection and Broadband
Broadband modem? Cable or DSL?
You do not connect a broadband modem to a regular telephone line (unless you
have DSL service activated and a filter on your telephone line).
Broadband is always on and does not require dialing.
You should be able to set up your PCMCIA modem using dial up.
I Bleed Blue and Gold
GO BEARS!
"Kevin Mc" <Kevin Mc@discussions.microsoft.com> wrote in message
news:C59A3EA1-5AED-4EA4-809C-73234C3DADB1@microsoft.com...
> and a PCMCIA modem.
Old 06-15-2007   #3 (permalink)
Kevin Mc
Guest
Sprint broadband card for laptop. Novatel U720. Device manager recognizes it
as a modem and a query shows a success response but I can't create a
connection for it. It works fine on my XP box but I can't get Vista to work
with it.
> GO BEARS!
> > and a PCMCIA modem.
Old 06-15-2007   #4 (permalink)
Michael Price
Guest
Did you download the latest Vista drivers from the sprint site?
I had one of these cards on a trial and it worked fine for me.
"Kevin Mc" <KevinMc@discussions.microsoft.com> wrote in message
news:03F73101-5967-4533-A981-9E16B93408A3@microsoft.com...
> it
> work
> with it.
>> you
>> GO BEARS!
>> >recognizes
>> > Keep
>> > a USB
>> > and a PCMCIA modem.
Old 06-16-2007   #5 (permalink)
Kevin Mc
Guest
Hi Michael:
Yea I have the latest and greatest drivers. I tried Sprint,Toshiba(my
laptop) and even a German made generic broadband software (NWCom). The issue
might be that for some reason I either don't have the rights (tried as
administrator as well) or for some reason can't create a new connection in
the Network control panel. I had a friend try it on their Dell Vista laptop
and it worked fine for them.
I am a bit puzzled, I tried going to DOS and changing the Attributes for
the Windows directory but they were already set to A so I didn't bother
pursuing that path.
-Kevin
> > it
> > work
> > with it.
> >> you
> >> GO BEARS!
> >> >recognizes
> >> > Keep
> >> > a USB
> >> > and a PCMCIA modem.
Old 06-18-2007   #6 (permalink)
pawan.sahni@gmail.com
Guest
On Jun 16, 8:55 pm, Kevin Mc <Kevi...@discussions.microsoft.com>
wrote:
> Hi Michael:
> pursuing that path.
> -Kevin
> > "Kevin Mc" <Kevi...@discussions.microsoft.com> wrote in message
> > > it
> > > work
> > > with it.
> > >> you
> > >> GO BEARS!
> > >> "Kevin Mc" <Kevin M...@discussions.microsoft.com> wrote in message
> > >> >recognizes
> > >> > Keep
> > >> > a USB
> > >> > and a PCMCIA modem.- Hide quoted text -
> - Show quoted text -
Did you find any solution. Its been a week i have been trying to
install a modem but havent been able to get thru
Pawan
On Broadband But Dial-up Pop-up In WM Vista mail
dial up to broadband DSL wireless plz help Network & Sharing
Connection is offered , dial up and broadband, thru modem, when I´m actually connected by cable... Vista General
More Security With Windows Dial-Up Internet Connection Than With Broadband? Vista security
More Security With Windows Dial-Up Internet Connection Than With Broadband? Vista General
