1.    15 Jun 2007 #1
    clarkgable Guest
    'A patch is preventing the system from starting'
    I am dual booting xp prof with vista ultimate, and have been using vista as
    my primary os for the last 7 months or so.
    I did an vista update last week, and on restarting the pc, vista wouldn't
    boot. i then logged onto xp to make sure my pc was fine, and it was just
    vista playing up. i then decided to use the vista dvd to attempt system
    repair. system repair failed, and came up with the following:
    Startup Repair diagnosis and repair log
    Last successful boot time: 6/7/2007 4:57:18 PM (GMT)
    Number of repair attempts: 7
    Session details
    System Disk = \Device\Harddisk0
    Windows directory = C:\Windows
    AutoChk Run = 0
    Number of root causes = 1
    Root cause found:
    A patch is preventing the system from starting.
    The fact that a patch was preventing the system from starting made me think
    that if i attempted system restore, i'll be able to go back to it was before
    the update. unfortunately, i have subsequently learnt that logging into xp
    wiped away any system restore information that i had!
    i was able to get some stop information on the BSOD as well, with the result
    being:
    STOP: 0x0000007B (0x83006BA0, 0xC0000034, 0X00000000, 0x00000000)
    i have tried all the safe mode options, and it gives me the same problem.
    the last update i did was for a realtek lan card, which might be the faulty
    patch. since then i have removed the card, and even installed a new
    motherboard, as i was having problems with the other one. i have a
    4coredual-vsta.
    i could do a re-install, i have the dvd, but it is a nuisance that i would
    rather avoid if anyway possible.
    so the question i have is, has anyone fixed this problem without having to
    reinstall, and also is there anything i can do to fix it from inside xp?
    Thanks in advance (and sorry for the long post)
  2.    15 Jun 2007 #2
    NotMe Guest
    Re: 'A patch is preventing the system from starting'
    As I remember the 7B stop error is a failure of the system to communicate
    with the HDD.
    Either it is corrupted or defective, bad I/O controller, etc.
    I have had to format to overcome that, but there may be another solution, I
    just don't know what it is.
    http://msdn2.microsoft.com/en-gb/library/ms795508.aspx
    search for 'stop error' at http://www.aumha.org/kb.htm
    A Professional Amateur...If anyone knew it all, none of would be here!
    CarGodZeroOne@hotmail.com
    Change Alpha to Numeric to reply
    "clarkgable" <clarkgable@discussions.microsoft.com> wrote in message
    news:03009008-B618-4829-BD81-927D6418F14C@microsoft.com...
    > Session details
    > AutoChk Run = 0
    > Root cause found:
    > think
    > before
    > result
    > being:
    > faulty
    > 4coredual-vsta.
System Restore starting
This will probably be the idiot question of the month so I apologize in advance. In an nVidea forum some member updated his drivers and now...
General Discussion
problem preventing the troubleshooter from starting.
How to fix 0x80092003 and 0x803C0107 and 0x80070005 problem? Lee Hoy Chin
Crashes and Debugging
hp vista not booting, system recovery not starting
hey i have a hp g 60 notebook and the vista is not starting up on it. i have been using this computer for an year now, yesterday while playing a...
A patch is preventing the system from starting. - Which one?
So I am a good techie and patch my system regularly. I am running Vista x64 Ultimate SP1. Up until a few weeks ago no problem. I log on and windows...
Vista General
Windows Easy Transfer restore to a partially restored Ultimate system config-preventing duplication issues?
::My original Vista Ultimate setup included 2 Users (myself and wife) both with Admin rights, and therefore we had two User default folder trees...
Vista installation & setup
System Configuration keeps starting up with Windows Vista
For some reason, every time I start my pc, system configuration automatically starts up with the pc telling me that I have made changes to the way...
Vista General
System Administrator stops installation of patch
Vista Home Premium Operating System. Downloaded a patch from genealogy software needed because of Vista. When attempting to install the patch, I...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
