Two Remote Desktop Users at the same time ??
  1.    16 Jun 2007 #1
    Synapse Syndrome Guest
    Is there any way to let two users use a [Vista Ultimate] desktop machine at
    the same time?
    Windows Server 2003 allows two concurrent connection through RDP for
    administration mode.
    Also, the later specification for Smart Display 1.5 (Mira), allowed the
    display to use the Windows XP host to run one normal user at the computer
    simultaneously with the Smart Display user.
    I am looking to be able to use my Vista Ultimate desktop machine in a
    similar way. I want to be able to use it normally at the desk with one user
    account, and have a laptop connect to it using RDP in another user account.
    When I try this I get a screen saying that the only way I can connect would
    be by knocking off the other user.
    Is there any possible way to do this without using a Windows Server machine
    with Terminal Services?
    I want to avoid compromising and using the same user account through
    something like VNC or TeamViewer.
    Cheers
    ss.
  2.    16 Jun 2007 #2
    Tiberius Guest
    Re: Two Remote Desktop Users at the same time ??
    there was a patch for xpsp2 that gave you as many users as you wanted....
    perhaps they will make one for vista as well
    "Synapse Syndrome" <synapse@NOSPAMgomez404.elitemail.org> wrote in message
    news:OIdybtBsHHA.4180@TK2MSFTNGP04.phx.gbl...
    > at the same time?
    > user account, and have a laptop connect to it using RDP in another user
    > account.
    > would be by knocking off the other user.
    > machine with Terminal Services?
    > Cheers
    > ss.
  3.    16 Jun 2007 #3
    The title of this thread should actually be something like:
    "Two conncurrent user at the same time, one using RDP ??"
    ss.
  4.    16 Jun 2007 #4
    "Tiberius" <Jim@Tib.Kirk> wrote in message
    news:uKOiJwBsHHA.2240@TK2MSFTNGP03.phx.gbl...
    Oh really? I never heard of that. Does that patch still work, or did MS
    repatch the patch through Windows Update?
    ss.
  5.    16 Jun 2007 #5
    Shenan Stanley Guest
    > machine at the same time?
    > the display to use the Windows XP host to run one normal user at
    > the computer simultaneously with the Smart Display user.
    > a similar way. I want to be able to use it normally at the desk
    > with one user account, and have a laptop connect to it using RDP in
    > connect would be by knocking off the other user.
    Having given my first response - I stand by it (no supported method) - but I
    did state it was possible for Windows XP using a 'hack' and files from the
    beta of SP2.
    Have you even searched for a solution on your own?
    My first search for "concurrent remote desktop Vista" came up with hacks
    similar to those for XP - but 'unsupported' and "risky" are still part of
    the equation. After all you are replacing system files with those whose
    contents - you do not know where they came from.
    Shenan Stanley
    MS-MVP
    How To Ask Questions The Smart Way
    http://www.catb.org/~esr/faqs/smart-questions.html
  6.    16 Jun 2007 #6
    Yes - it is a server OS.
    Third party applications - although there was a hack by which you used a
    file from a beta release of SP2 and could remote into the machine
    concurrently.
    Perhaps with a third party program - but I am unaware of any for Vista at
    this time.
    True.
    Not that has been published as supported.
    Again - you'd have to look for some third party application...
    Shenan Stanley
    MS-MVP
  7.    16 Jun 2007 #7
    "Shenan Stanley" <newshelper@gmail.com> wrote in message
    news:ercS1$BsHHA.5024@TK2MSFTNGP06.phx.gbl...
    > concurrently.
    No, Smart Display was a Microsoft initiative. It failed because it was too
    expensive.
    http://www.microsoft.com/windows/sma...y/default.mspx
    http://en.wikipedia.org/wiki/Smart_Display
    ss.
  8.    16 Jun 2007 #8
    news:OrJQf6BsHHA.4860@TK2MSFTNGP02.phx.gbl...
    These chosen newsgroups seemed to be the natural place to ask people that
    might have had some experience with this.
    Thanks, I'll have a look at these. I would guess that the files came from
    Windows Server 2003.
    ss.
  9.    16 Jun 2007 #9
    > people that might have had some experience with this.
    Yes - but just because you can ask doesn't mean you shouldn't put in some
    effort on your own first... ;-)
    > hacks similar to those for XP - but 'unsupported' and "risky" are
    > still part of the equation. After all you are replacing system
    > files with those whose contents - you do not know where they came
    > from.
    > came from Windows Server 2003.
    No idea - they claim to be hacked... The definition of 'hacked' is pretty
    broad these days.
    Shenan Stanley
    MS-MVP
  10.    16 Jun 2007 #10
    Tiberius Guest
    It works
    there are links and downloads for it here
    http://www.google.com/search?q=Termi...x=&startPage=1
    news:%23MK0D2BsHHA.404@TK2MSFTNGP06.phx.gbl...
    > ss.
Page 1 of 2 12 LastLast
Microsoft Urges Users To Patch Critical Remote Desktop Vulnerability
Read more at: Maximum PC | Microsoft Urges Windows Users To Patch Critical Remote Desktop Vulnerability ASAP
Vista News
can only see local machine users when trying to add users allowed for remote desktop access
Hi, I have a windows 2003 server on my network(its actually a virtual machine running on windows server 2008), that I have enabled remote access...
Server General
Strategy to Remote Desktop multiple users simultanously
I have a about 10 quite old WinXP PC's whose owners now moved offsite but still access documents and applications remotely using Remote Desktop...
Server General
Re: List users connected via Remote Desktop & console?
I would also like to parse the output of qwinsta via vbscript. However, I am not sure how to accomplish this in order to show only "rdp-tcp#" or...
VB Script
Windows System Time and Desktop time not matching up
I have recently gotten a laptop and I have had to change the time on my computer back to a deifferent time zone for traveling, and I was able to...
Vista General
Switch users under Remote Desktop
I have to remotely administer a couple of computers (Vista Business) that run standalone, we are not part of any kind of network/domain. I've got...
Vista account administration
2 users simultaneously with Remote Desktop
I have 2 questions regarding RDP functionality with Vista: 1. I want to be able to establish an RDP session to my home PC while another user is...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
