| | which monitor to use under display settings? hey sorry about all the questions but when installing updates i chose to install optional updates as well and one of them was a BenQ FP91G+ (analog) on NVIDI GeForce 7300 GS and my second is (default monitor) on NVIDI GeForce 7300. My question is what's the difference between the 2? and what does the (analog) part mean in the first one? and which one is the better option? The BenQ one is set to number 1 and the other is set to 2 im scared that i have changed settings and may have caused a problem within vista because i downloaded that and dont know how to get rid of it because i cant find that particular update in the uninstall updates option. Any advice? thanks in advance |
| | Re: which monitor to use under display settings? hello... don't be scared.. the monitor names and drivers are only to tell windows what resolutions and refresh rates that can work on, so you wont go beyond its limits these drivers are not necessary for the monitor to work, as other drivers are for other hardware.. Do you have 2 monitors on your computer? "bluestone" <bluestone@discussions.microsoft.com> wrote in message news:00800364-F1EC-47E2-B173-B95FDE8B4B3E@microsoft.com... > hey sorry about all the questions but when installing updates i chose to > install optional updates as well and one of them was a BenQ FP91G+ > (analog) > on NVIDI GeForce 7300 GS and my second is (default monitor) on NVIDI > GeForce > 7300. My question is what's the difference between the 2? and what does > the > (analog) part mean in the first one? and which one is the better option? > The > BenQ one is set to number 1 and the other is set to 2 im scared that i > have > changed settings and may have caused a problem within vista because i > downloaded that and dont know how to get rid of it because i cant find > that > particular update in the uninstall updates option. Any advice? thanks in > advance |
| | Re: which monitor to use under display settings? The presence of #1 and #2 monitors in the display settings panel suggests that your computer has a video card capable of having two monitors attached. If you do have two monitors attached each one has its own settings; if not, then adjust the #1 display and leave #2 alone. -- Richard G. Harper [MVP Shell/User] rgharper@gmail.com * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ * HELP us help YOU ... http://www.dts-l.org/goodpost.htm "bluestone" <bluestone@discussions.microsoft.com> wrote in message news:00800364-F1EC-47E2-B173-B95FDE8B4B3E@microsoft.com... > hey sorry about all the questions but when installing updates i chose to > install optional updates as well and one of them was a BenQ FP91G+ > (analog) > on NVIDI GeForce 7300 GS and my second is (default monitor) on NVIDI > GeForce > 7300. My question is what's the difference between the 2? and what does > the > (analog) part mean in the first one? and which one is the better option? > The > BenQ one is set to number 1 and the other is set to 2 im scared that i > have > changed settings and may have caused a problem within vista because i > downloaded that and dont know how to get rid of it because i cant find > that > particular update in the uninstall updates option. Any advice? thanks in > advance |
| | Re: which monitor to use under display settings? On Sat, 16 Jun 2007 08:27:03 -0700, bluestone <bluestone@discussions.microsoft.com> wrote: >hey sorry about all the questions but when installing updates i chose to >install optional updates as well and one of them was a BenQ FP91G+ (analog) >on NVIDI GeForce 7300 GS and my second is (default monitor) on NVIDI GeForce >7300. My question is what's the difference between the 2? and what does the >(analog) part mean in the first one? and which one is the better option? Digital is ALWAYS better then analog because it is a simple pass through with no additional processing steps that can reduce the quality of the signal. You should only use Analog connections if your monitior and/or graphic card doesn't support the newer standard. You can easily see the difference in the connectors. |
| | Re: which monitor to use under display settings? i think i had only one monitor but when i used the updates i updated some optional things as well and it downloaded the second Benq analoge monitor and now i dont know how to get rid of it. Currently my default one is set to screen number 2 but its not active and i only have 1 screen. The anagloe one is set as number one with higher resolution. How do you change it and make the default one (the non analoge one) as the primary screen? "Adam Albright" wrote: > On Sat, 16 Jun 2007 08:27:03 -0700, bluestone > <bluestone@discussions.microsoft.com> wrote: > > >hey sorry about all the questions but when installing updates i chose to > >install optional updates as well and one of them was a BenQ FP91G+ (analog) > >on NVIDI GeForce 7300 GS and my second is (default monitor) on NVIDI GeForce > >7300. My question is what's the difference between the 2? and what does the > >(analog) part mean in the first one? and which one is the better option? > > Digital is ALWAYS better then analog because it is a simple pass > through with no additional processing steps that can reduce the > quality of the signal. You should only use Analog connections if your > monitior and/or graphic card doesn't support the newer standard. You > can easily see the difference in the connectors. > > |
| Vista logon changes Dual monitor display settings | Vista General | |||
| HELP! Monitor Settings Issues: Can't Alter the Monitor Settings... | Vista hardware & devices | |||
| Dual monitor display settings revert on startup | Vista General | |||
| Loosing Display Settings On Monitor | Vista hardware & devices | |||
| Monitor Not In Selection List in Display Settings in Vista Ultimate | Vista hardware & devices | |||
