| | Show Dial-Up Connection on System Tray? I'm new to Vista and am still trying to get use to it. I have DSL on a Local Network (shared with laptop), and use Dial-Up as a backup. In XP, when connected via the Dial-Up, the connection would be shown on the System Tray. So far, in Vista, it is not shown when connected. How do I get the connection to show on the System Tray in Vista when connected? Thanks Charliec ****************************************************** Charliec |
| | Re: Show Dial-Up Connection on System Tray? Right click the Start Orb on the Taskbar, select Properties, Notification Area tab, check Network system icon -- I Bleed Blue and Gold GO BEARS! "Charliec" <charliec@invalid.address.com> wrote in message news:jvva73lf53lrqpta31o1m16di8udn22bij@4ax.com... > I'm new to Vista and am still trying to get use to it. I have DSL on > a Local Network (shared with laptop), and use Dial-Up as a backup. In > XP, when connected via the Dial-Up, the connection would be shown on > the System Tray. So far, in Vista, it is not shown when connected. > How do I get the connection to show on the System Tray in Vista when > connected? > > Thanks > Charliec > ****************************************************** > Charliec |
| | Re: Show Dial-Up Connection on System Tray? Thanks for the reply. I looked at that and the Network Icon is already checked. Any other thoughts? Charliec >On Sun, 17 Jun 2007 14:47:55 -0400, "Cal Bear '66" <xxx@xxx.org> wrote: >Right click the Start Orb on the Taskbar, select Properties, Notification Area >tab, check Network system icon ****************************************************** Charliec |
| Powershell to show Icons in the System Tray | PowerShell | |||
| Show date in system tray | Vista General | |||
| Show Dial-up Connection on System Tray | Vista General | |||
| Dial-up how to show connection activity? | Vista networking & sharing | |||
| Show seconds on clock in System tray? | Vista General | |||
