Vista Tutorial - 64bit dowload problem!
Old 06-21-2006   #1 (permalink)
Tommy
Guest
Try too download 64bit vista whid downloadmanager but it say that the file is
too big for my win xp?
Old 06-21-2006   #2 (permalink)
Jane C
Guest
Re: 64bit dowload problem!
If your XP is formatted as FAT32, then yes, the file will be too big. FAT32
formatted drives can only handle file sizes up to 4GB. You would need to
have your XP hard drive formatted as NTFS to be able to save files over the
4GB limit.
Jane, not plain 64bit enabled
Batteries not included. Braincell on vacation
"Tommy" <Tommy@discussions.microsoft.com> wrote in message
news:73D4F13B-580D-46DB-B83E-BAEA0CECAA0A@microsoft.com...
> is
Old 06-22-2006   #3 (permalink)
2
Guest
Too stupid for a beta OS.
When you help someone like this they will just be back in a few more
days with more stupid question.
This group is being flooded with moronic questions:
How do I get a product key
Where do I get a driver for xyz hardware
Won't install on my lapotop
Won't install on my computer circa 1968
My crappy video card won't run aero glass (the sky is falling)
My crappy sound card doesn't work
Can't figure out how to activate
Will my 16 bit program from 1992 run on Vista
How long can I use Vista Beta
How do I dual boot
I NEED STEP BY STEP INSTRUCTIONS HOW TO GET XP BACK
cannot delete windows.old file
Ignore them, children should only listen to adult conversations, not
be incouraged to join in.
On Wed, 21 Jun 2006 02:09:02 -0700, Tommy
Dowload Speed Problem with FlashGet Network & Sharing
65 mb or 427 mb sp1 dowload? Vista General
dowload programs Vista file management
Dowload updates from hp.com Vista General
dowload vista Vista installation & setup
