Vista - Remote desktop connection works in XP not in Vista Ultimate
Old 06-18-2007   #1 (permalink)
Jeff
I installed Vista Ultimate from Windows XP. Remote desktop connection worked
fine on XP, but Vista doesn't even try to connect. It puts an error screen
up that says: This computer can't connect to the remote computer.
It further says this might be due to low virtual memory on your computer. I
don't have anything else open. I have 1 gig of RAM installed plus a large
virtual memory on the hard drive.
Is there a bug here or is there something I am missing.
Old 06-19-2007   #2 (permalink)
Lang Murphy
Re: Remote desktop connection works in XP not in Vista Ultimate
"Jeff" <Jeff@discussions.microsoft.com> wrote in message
news:B1C17BE1-8556-4ED5-96CC-9635C0878DE0@microsoft.com...
>worked
> screen
> I
You're trying to connect from Vista to what type of PC?
Lang
Old 06-19-2007   #3 (permalink)
Jeff
I am trying to connect to a Windows XP PC on a network. It worked well
previously using Windows XP on this same PC prior to the upgrade.
> >worked
> > screen
> > I
> Lang
Old 06-19-2007   #4 (permalink)
Lang Murphy
news:786B0473-051F-41F1-9332-7585B70DFEFB@microsoft.com...
>> >worked
>> > screen
>> > computer.
>> > I
>> > large
>> Lang
Okay... I was just trying to verify that you weren't trying to RD into an XP
Home box.
Can you ping the XP box from the Vista box?
Lang
Old 06-19-2007   #5 (permalink)
Jeff
No, I get the error message as soon as I select "connect".
> >> >worked
> >> > screen
> >> > computer.
> >> > I
> >> > large
> >> Lang
> Home box.
> Lang
Old 06-21-2007   #6 (permalink)
Lang Murphy
news:73F5D47E-03B8-4AB5-9048-5C62C0217899@microsoft.com...
>> >> >connection
>> >> >worked
>> >> > screen
>> >> > computer.
>> >> > I
>> >> > large
>> >> Lang
>> XP
>> Home box.
>> Lang
No... that's not what I'm talking about... open a cmd window with admin
rights (open Start Orb, type "cmd" in the search window, right click on
cmd.exe at top of start window and select Run As Administrator). In the cmd
window, type "ping <computer name>" if that fails, try typing "ping
<computer's IP>. We're just trying to verify that one box "sees" the other
over the network. If pinging the computer name works, then, uh, not sure
where to go from here. If pinging the computer name fails, but pinging the
IP works, try connecting via RD to the IP. If pinging to the IP fails, then
there's something wrong with your network settings on either one or both of
the PC's.
Lang
old winterm 3000 series cannot connect to Vista Ultimate RDP remote desktop connection Vista hardware & devices
Vista Remote Desktop Connection no longer works Vista General
Remote desktop connection Vista Ultimate Vista networking & sharing
Remote desktop connection Vista Ultimate Vista General
Remote Desktop Connection in Vista Ultimate Vista General
