| | Changing Power Plans Does anyone know if there is a way for Vista to automatically switch from using Power Saver when I'm on battery, to High Performance when it is plugged in? |
| | Re: Changing Power Plans I don't know if there's a way to make Vista automatically switch between two plans, but any plan has settings for both on battery and on AC. You can modify (and save to a new name) any of the existing plans to suit your needs. CPU performance, display brightness, time-outs for sleep/hibernate, etc are all configurable. Control Panel/ Power Options, select Change plan Settings for one of the plans, select Change Advanced power settings. Lots of options. Val "Jason T" <JasonT@discussions.microsoft.com> wrote in message news:6E0F136A-E920-432D-AF96-C2128CCCD284@microsoft.com... > Does anyone know if there is a way for Vista to automatically switch from > using Power Saver when I'm on battery, to High Performance when it is > plugged > in? |
| Power plans help please?? | General Discussion | |||
| power plans | Vista General | |||
| Show more than 3 Power Plans ? | Vista performance & maintenance | |||
| Changing power plans shown on battery meter | Vista performance & maintenance | |||
| Power Plans | Vista performance & maintenance | |||
