| | 32 bit operating system w/duo core 64bit processor I am confused about the new computer I bought. It says that I have a 32 bit operating system but a duo core 64 bit processor. So which type of computer do I have, 32bit or 64bit, Help! |
| | Re: 32 bit operating system w/duo core 64bit processor 64 "pdeajw" <pdeajw@discussions.microsoft.com> wrote in message news:C1BB8AC5-3E71-4D6B-A4C3-13F7CE0154DF@microsoft.com... >I am confused about the new computer I bought. It says that I have a 32 bit > operating system but a duo core 64 bit processor. So which type of > computer > do I have, 32bit or 64bit, Help! |
| | Re: 32 bit operating system w/duo core 64bit processor You have a 32-bit/64-bit capable computer that is running a 32-bit operating system. You can install a 64-bit operating system and then you will have a 32-bit/64-bit computer running a 64-bit operating system. -- I Bleed Blue and Gold GO BEARS! "pdeajw" <pdeajw@discussions.microsoft.com> wrote in message news:C1BB8AC5-3E71-4D6B-A4C3-13F7CE0154DF@microsoft.com... >I am confused about the new computer I bought. It says that I have a 32 bit > operating system but a duo core 64 bit processor. So which type of computer > do I have, 32bit or 64bit, Help! |
| | Re: 32 bit operating system w/duo core 64bit processor "pdeajw" <pdeajw@discussions.microsoft.com> wrote in message news:C1BB8AC5-3E71-4D6B-A4C3-13F7CE0154DF@microsoft.com... >I am confused about the new computer I bought. It says that I have a 32 bit > operating system but a duo core 64 bit processor. So which type of > computer > do I have, 32bit or 64bit, Help! Cal Bear was pretty darn close to communicating the truth. For usability purposes, since in layman's terms a computer is the whole user experience of operating system and hardware combined, your computer is currently a 32-bit computer. You can upgrade your computer to 64-bit, but that would be an operating system upgrade (software), not a hardware upgrade. Technically, you have a 64-bit processor that supports both 32-bit and 64-bit instruction sets. This is called 64-bit Extended (or x64 / EM64). But since the operating system is 32-bit, you can only run 32-bit software, unless the software expressly describes itself as 64-bit software that supports 32-bit operating systems (such as VMWare Workstation or the 64-bit flavor of Cakewalk Sonar). If you install a 64-bit Extended operating system, such as Windows Vista x64, then you will be able to run either 32-bit software or 64-bit software. Some 64-bit hardware only supports 64-bit software. This isn't the case here because your operating system is already 32-bit. Jon |
| | Re: 32 bit operating system w/duo core 64bit processor On Wed, 20 Jun 2007 18:09:52 -0700, pdeajw wrote: > I am confused about the new computer I bought. It says that I have a 32 bit > operating system but a duo core 64 bit processor. So which type of computer > do I have, 32bit or 64bit, Help! Well, it sounds to me like you have a 64 bit computer running a 32 bit system. |
| | #6 (permalink) |
| | Re: 32 bit operating system w/duo core 64bit processor And if this computer was dual-boot with a 64bit OS, it would be what? It's a 64bit computer... regardless of any installed OS. "Jon Davis" <jon@REMOVE.ME.PLEASE.jondavis.net> wrote in message news:#Uz9dQ6sHHA.1188@TK2MSFTNGP04.phx.gbl... > > "pdeajw" <pdeajw@discussions.microsoft.com> wrote in message > news:C1BB8AC5-3E71-4D6B-A4C3-13F7CE0154DF@microsoft.com... >>I am confused about the new computer I bought. It says that I have a 32 >>bit >> operating system but a duo core 64 bit processor. So which type of >> computer >> do I have, 32bit or 64bit, Help! > > Cal Bear was pretty darn close to communicating the truth. > > For usability purposes, since in layman's terms a computer is the whole > user experience of operating system and hardware combined, your computer > is currently a 32-bit computer. You can upgrade your computer to 64-bit, > but that would be an operating system upgrade (software), not a hardware > upgrade. > > Technically, you have a 64-bit processor that supports both 32-bit and > 64-bit instruction sets. This is called 64-bit Extended (or x64 / EM64). > But since the operating system is 32-bit, you can only run 32-bit > software, unless the software expressly describes itself as 64-bit > software that supports 32-bit operating systems (such as VMWare > Workstation or the 64-bit flavor of Cakewalk Sonar). If you install a > 64-bit Extended operating system, such as Windows Vista x64, then you will > be able to run either 32-bit software or 64-bit software. > > Some 64-bit hardware only supports 64-bit software. This isn't the case > here because your operating system is already 32-bit. > > Jon > |
| | #7 (permalink) |
| | Re: 32 bit operating system w/duo core 64bit processor You are running a 64 Bit processor, but using the 32Bit version of Vista. It is perfectly ok, and if you don't have a need for 64 Bit, I wouldn't worry about it one bit. They are about equal on speed, for the time being. The Core 2 Duo is a screamer either way. A 64 Bit version of Vista is available, but if you have no need to upgrade, I wouldn't. There are a few driver challenges (getting better everyday, though), and some applications won't work with 64 Bit. -- Dustin Harper dharper@vistarip.com http://www.vistarip.com -- "pdeajw" <pdeajw@discussions.microsoft.com> wrote in message news:C1BB8AC5-3E71-4D6B-A4C3-13F7CE0154DF@microsoft.com... >I am confused about the new computer I bought. It says that I have a 32 bit > operating system but a duo core 64 bit processor. So which type of > computer > do I have, 32bit or 64bit, Help! |
| | #8 (permalink) |
| | Re: 32 bit operating system w/duo core 64bit processor On Wed, 20 Jun 2007 18:09:52 -0700, pdeajw <pdeajw@discussions.microsoft.com> wrote: > I am confused about the new computer I bought. It says that I have a 32 bit > operating system but a duo core 64 bit processor. So which type of computer > do I have, 32bit or 64bit, Help! You have exactly what it says you have. Your processor is 64-bit. That means it can run either a 32-bit or 64-bit version of Windows. You are running the 32-bit version. -- Ken Blake, Microsoft MVP Windows - Shell/User Please Reply to the Newsgroup |
| | #9 (permalink) |
| | Re: 32 bit operating system w/duo core 64bit processor A 48 bit computer. Amir "Mac" <mac@nospam.com> wrote in message news:uTJzfV6sHHA.2164@TK2MSFTNGP02.phx.gbl... > And if this computer was dual-boot with a 64bit OS, it would be what? > > It's a 64bit computer... regardless of any installed OS. > > "Jon Davis" <jon@REMOVE.ME.PLEASE.jondavis.net> wrote in message > news:#Uz9dQ6sHHA.1188@TK2MSFTNGP04.phx.gbl... >> >> "pdeajw" <pdeajw@discussions.microsoft.com> wrote in message >> news:C1BB8AC5-3E71-4D6B-A4C3-13F7CE0154DF@microsoft.com... >>>I am confused about the new computer I bought. It says that I have a 32 >>>bit >>> operating system but a duo core 64 bit processor. So which type of >>> computer >>> do I have, 32bit or 64bit, Help! >> >> Cal Bear was pretty darn close to communicating the truth. >> >> For usability purposes, since in layman's terms a computer is the whole >> user experience of operating system and hardware combined, your computer >> is currently a 32-bit computer. You can upgrade your computer to 64-bit, >> but that would be an operating system upgrade (software), not a hardware >> upgrade. >> >> Technically, you have a 64-bit processor that supports both 32-bit and >> 64-bit instruction sets. This is called 64-bit Extended (or x64 / EM64). >> But since the operating system is 32-bit, you can only run 32-bit >> software, unless the software expressly describes itself as 64-bit >> software that supports 32-bit operating systems (such as VMWare >> Workstation or the 64-bit flavor of Cakewalk Sonar). If you install a >> 64-bit Extended operating system, such as Windows Vista x64, then you >> will be able to run either 32-bit software or 64-bit software. >> >> Some 64-bit hardware only supports 64-bit software. This isn't the case >> here because your operating system is already 32-bit. >> >> Jon >> |
| | #10 (permalink) |
| | Re: 32 bit operating system w/duo core 64bit processor "Mac" <mac@nospam.com> wrote in message news:uTJzfV6sHHA.2164@TK2MSFTNGP02.phx.gbl... > And if this computer was dual-boot with a 64bit OS, it would be what? > > It's a 64bit computer... regardless of any installed OS. I disagree. I qualified myself with "since in layman's terms a computer is the whole user experience of operating system and hardware combined". Tell my mother that her 64-bit hardware running a 32-bit operating system is a 64-bit computer, and she will start looking for 64-bit software to buy for it. Jon |
| quad core only operating on 2 cores | Vista hardware & devices | |||
| multi-core processor ................. | Vista General | |||
| Dual-Core Processor | Vista General | |||
| Dual core processor only ones on one core | Vista hardware & devices | |||
| Dual-core = one processor, right? | Vista General | |||
