Vista - problems installing vista
Old 06-21-2006   #1 (permalink)
joe shmoe
i have a
abit AI7
3gb crucial xms ram
40gb hard drive
i install it from the dvd and it gets to the funky background, then freezes
and restarts in a loop.
I tried installing it as an upgrade to winxp and as a new install and it
will go through the full install and at the end when its about to get to the
log in screen it says that it didn't install correctly and reverts back to xp.
any ideas
Old 06-21-2006   #2 (permalink)
Zapper
Re: problems installing vista
Is you machine overclocked? Do you have your memory running at an
"optomized"/"overclocked" speed?
"joe shmoe" <joe shmoe@discussions.microsoft.com> wrote in message
news:4E3A44B4-FF4C-4470-B272-2365B9BEC654@microsoft.com...
>i have a
> abit AI7
> 3gb crucial xms ram
> 40gb hard drive
> freezes
> the
> xp.
> any ideas
Old 06-21-2006   #3 (permalink)
jonah
On Wed, 21 Jun 2006 11:17:01 -0700, joe shmoe <joe
shmoe@discussions.microsoft.com> wrote:
>i have a
>abit AI7
>3gb crucial xms ram
>40gb hard drive
>any ideas
Probably errors on the DVD you installed from. Try burning another at
the lowest speed you can and burn it on the DVD drive you intend to
install it from to avoid minor inconsistancies between one DVD Drive
and another.
Jonah
Old 06-21-2006   #4 (permalink)
joe shmoe
> >i have a
> > abit AI7
> > 3gb crucial xms ram
> > 40gb hard drive
> > freezes
> > the
> > xp.
> > any ideas
nothing is overclocked i even tried disabling some things
Old 06-22-2006   #5 (permalink)
lttlbgft
RE: problems installing vista
I'm having the same issues! My first attempt to install gave me an error code
800703EE, which means it thought I didn't have the authority to upgrade. On
my second attempt it did exactly as you described, Joe. What gives?
Richard H-Carrollton, Ga-USA-Custom built system-See "About Me" for my
system specs.
"joe shmoe" wrote:
> i have a
> abit AI7
> 3gb crucial xms ram
> 40gb hard drive
> any ideas
Old 06-22-2006   #6 (permalink)
lttlbgft
my second attempt it did exactly as you described, Joe. What gives? I'm
using the CD sent to me from Micorsoft.
system specs.
"joe shmoe" wrote:
> i have a
> abit AI7
> 3gb crucial xms ram
> 40gb hard drive
> any ideas
Old 06-22-2006   #7 (permalink)
lttlbgft
system specs.
Old 06-22-2006   #8 (permalink)
lttlbgft
Sorry about the multiple post. The site told me that my replies had failed. I
guess it was wrong.
system specs.
Old 06-22-2006   #9 (permalink)
Colin Barnhorst
It's the web-based newsreader you are using. Try using the newsreader in
Vista Mail. The Vista newsgroups are already set up for you. All you have
to do is subscribe to the ones you want.
"lttlbgft" <lttlbgft@excite.com> wrote in message
news:66984960-C3FA-4BC4-B9B8-4B3F06B378B2@microsoft.com...
> failed. I
> guess it was wrong.
> system specs.
Old 06-22-2006   #10 (permalink)
Colin Barnhorst
Is your BIOS up to date?
>i have a
> abit AI7
> 3gb crucial xms ram
> 40gb hard drive
> freezes
> the
> xp.
> any ideas
Problems after installing Vista X64 General Discussion
Problems installing civ 4 on vista Gaming
vista installing problems General Discussion
Problems with installing XP over Vista Vista installation & setup
problems with installing vista Vista installation & setup
