| | Pen drive, USB memory stick not working on Vista I have recently upgraded from XP to Vista and my Pen Drives have stopped working. They still work on other computers. But when inserted in to my Vista machine it say new hardware detected and invites me to load drivers! The USB ports work with other devices, even other storage devices such as cameras and mp3 players. Any suggestions? Thanks Trekdigit |
| | Re: Pen drive, USB memory stick not working on Vista "Trekdigit" <Trekdigit@discussions.microsoft.com> wrote in message news:324139F7-9CC6-4C3F-89AC-3059AA210D23@microsoft.com... >I have recently upgraded from XP to Vista and my Pen Drives have stopped > working. They still work on other computers. But when inserted in to my > Vista machine it say new hardware detected and invites me to load drivers! > The USB ports work with other devices, even other storage devices such as > cameras and mp3 players. Any suggestions? > > Thanks > > Trekdigit > > The solution to this annoying problem (I have it on one PC), seems to be to locate and delete the file INFCACHE.1, which may be corrupted and causing the problem. To delete this file, you will first have to modify its permissions so the users group can access it (right-click on the file->Properties->Security). INFCACHE.1 file. It's located at C:\Windows\inf (scroll down to the file). That said. It didn't work for me, but appears to have worked for many. Good luck! |
| | Re: Pen drive, USB memory stick not working on Vista Aloha, I just wanted to thank you for this solution to the flash/pen drive problem. Windows Vista Ultimate was freezing everytime I tried to use a USB port and I almost gave up on it. The only thing it affected were the flash drives. Everything else worked fine. The first time I used the flash drives, they worked fine. It was configured to allow removal without "safely removing hardware". All of a sudden, Windows started freezing and since following your advice, everything works fine. The only difference was that the option of removing without permission is grayed out. Now I must use the "safely remove hardware" option when using the flash drive. Again, thank you. "PvdG42" <pvdg@toadstool.edu> wrote in message news:OBh%23JgNtHHA.4612@TK2MSFTNGP04.phx.gbl... > > "Trekdigit" <Trekdigit@discussions.microsoft.com> wrote in message > news:324139F7-9CC6-4C3F-89AC-3059AA210D23@microsoft.com... >>I have recently upgraded from XP to Vista and my Pen Drives have stopped >> working. They still work on other computers. But when inserted in to my >> Vista machine it say new hardware detected and invites me to load >> drivers! >> The USB ports work with other devices, even other storage devices such as >> cameras and mp3 players. Any suggestions? >> >> Thanks >> >> Trekdigit >> >> > > The solution to this annoying problem (I have it on one PC), seems to be > to locate and delete the file INFCACHE.1, which may be corrupted and > causing the problem. To delete this file, you will first have to modify > its permissions so the users group can access it (right-click on the > file->Properties->Security). > > INFCACHE.1 file. It's located at C:\Windows\inf (scroll down to the > file). > > That said. It didn't work for me, but appears to have worked for many. > > Good luck! > |
| | Re: Pen drive, USB memory stick not working on Vista "Ace" <acefarm@hawaii.rr.com> wrote in message news:1E24707B-6809-40F2-919B-E739E2E24FE6@microsoft.com... > Aloha, > I just wanted to thank you for this solution to the flash/pen drive > problem. Windows Vista Ultimate was freezing everytime I tried to use a > USB port and I almost gave up on it. The only thing it affected were the > flash drives. Everything else worked fine. The first time I used the flash > drives, they worked fine. It was configured to allow removal without > "safely removing hardware". All of a sudden, Windows started freezing and > since following your advice, everything works fine. The only difference > was that the option of removing without permission is grayed out. Now I > must use the "safely remove hardware" option when using the flash drive. > Again, thank you. > Thanks for the feedback ![]() I'm glad it worked for you. |
| | Re: Pen drive, USB memory stick not working on Vista Well, I glad it worked for Ace, Sadly it didn't work for me. Anybody got any other suggestions? Trekdigit "PvdG42" wrote: > > "Ace" <acefarm@hawaii.rr.com> wrote in message > news:1E24707B-6809-40F2-919B-E739E2E24FE6@microsoft.com... > > Aloha, > > I just wanted to thank you for this solution to the flash/pen drive > > problem. Windows Vista Ultimate was freezing everytime I tried to use a > > USB port and I almost gave up on it. The only thing it affected were the > > flash drives. Everything else worked fine. The first time I used the flash > > drives, they worked fine. It was configured to allow removal without > > "safely removing hardware". All of a sudden, Windows started freezing and > > since following your advice, everything works fine. The only difference > > was that the option of removing without permission is grayed out. Now I > > must use the "safely remove hardware" option when using the flash drive. > > Again, thank you. > > > Thanks for the feedback ![]() > I'm glad it worked for you. > > |
| | #6 (permalink) |
| | Re: Pen drive, USB memory stick not working on Vista You might try deleting them in device manager and/or reinstalling them...... not sure what that would do however.............. "Trekdigit" <Trekdigit@discussions.microsoft.com> wrote in message news:14DDF047-2816-4C6B-A8DA-26EF33D74F7D@microsoft.com... > Well, I glad it worked for Ace, Sadly it didn't work for me. Anybody got > any > other suggestions? > > Trekdigit > > "PvdG42" wrote: > >> >> "Ace" <acefarm@hawaii.rr.com> wrote in message >> news:1E24707B-6809-40F2-919B-E739E2E24FE6@microsoft.com... >> > Aloha, >> > I just wanted to thank you for this solution to the flash/pen drive >> > problem. Windows Vista Ultimate was freezing everytime I tried to use a >> > USB port and I almost gave up on it. The only thing it affected were >> > the >> > flash drives. Everything else worked fine. The first time I used the >> > flash >> > drives, they worked fine. It was configured to allow removal without >> > "safely removing hardware". All of a sudden, Windows started freezing >> > and >> > since following your advice, everything works fine. The only difference >> > was that the option of removing without permission is grayed out. Now I >> > must use the "safely remove hardware" option when using the flash >> > drive. >> > Again, thank you. >> > >> Thanks for the feedback ![]() >> I'm glad it worked for you. >> >> |
| | #7 (permalink) |
| | Re: Pen drive, USB memory stick not working on Vista "Spirit" <unknown@lost.info> wrote in message news:uAxRvxwtHHA.1212@TK2MSFTNGP05.phx.gbl... > You might try deleting them in device manager and/or reinstalling > them...... > not sure what that would do however.............. > Heh... Thank you! After deleting INFCACHE, I still could not use USB memory sticks, but based on your suggestion, I went back and deleted INFCACHE.1 again, then removed my USB hubs from Device manager and rebooted. Now Vista can find the drivers and my sticks can be used. |
| | #8 (permalink) |
| | Re: Pen drive, USB memory stick not working on Vista I have this Plug and Play BIOS Extension under System Devices in Device Manager. Is this a standard device of Windows Vista? Can I remove it? I have the same problem with Windows Vista not regconizing my PenDrive. may I know what do you mean by "deleting them in device manager and/or reinstalling them .. " Thanks "Spirit" wrote: > You might try deleting them in device manager and/or reinstalling them...... > not sure what that would do however.............. > > "Trekdigit" <Trekdigit@discussions.microsoft.com> wrote in message > news:14DDF047-2816-4C6B-A8DA-26EF33D74F7D@microsoft.com... > > Well, I glad it worked for Ace, Sadly it didn't work for me. Anybody got > > any > > other suggestions? > > > > Trekdigit > > > > "PvdG42" wrote: > > > >> > >> "Ace" <acefarm@hawaii.rr.com> wrote in message > >> news:1E24707B-6809-40F2-919B-E739E2E24FE6@microsoft.com... > >> > Aloha, > >> > I just wanted to thank you for this solution to the flash/pen drive > >> > problem. Windows Vista Ultimate was freezing everytime I tried to use a > >> > USB port and I almost gave up on it. The only thing it affected were > >> > the > >> > flash drives. Everything else worked fine. The first time I used the > >> > flash > >> > drives, they worked fine. It was configured to allow removal without > >> > "safely removing hardware". All of a sudden, Windows started freezing > >> > and > >> > since following your advice, everything works fine. The only difference > >> > was that the option of removing without permission is grayed out. Now I > >> > must use the "safely remove hardware" option when using the flash > >> > drive. > >> > Again, thank you. > >> > > >> Thanks for the feedback ![]() > >> I'm glad it worked for you. > >> > >> > > > |
| | #9 (permalink) |
| | Re: Pen drive, USB memory stick not working on Vista "Ned" <Ned@discussions.microsoft.com> wrote in message news:209723D6-504F-4A0F-B8D1-4584B1BF8177@microsoft.com... >I have this Plug and Play BIOS Extension under System Devices in Device > Manager. Is this a standard device of Windows Vista? Can I remove it? > > I have the same problem with Windows Vista not regconizing my PenDrive. > may > I know what do you mean by "deleting them in device manager and/or > reinstalling them .. " > > Thanks > Just delete the USB hubs from Device Manager. Vista will rediscover and reinstall them. Be sure to delete INFCACHE.1 first. |
| | #10 (permalink) |
| | Re: Pen drive, USB memory stick not working on Vista Just to make sure that I do not do the wrong things, I have 2 "USB Root Hub" and a "Standard Enhanced PCI to USB Host Controller" and a "Standard OpenHCD USB Host Controller". Which on should I delete? or do I need to remove them all? "PvdG42" wrote: > > "Ned" <Ned@discussions.microsoft.com> wrote in message > news:209723D6-504F-4A0F-B8D1-4584B1BF8177@microsoft.com... > >I have this Plug and Play BIOS Extension under System Devices in Device > > Manager. Is this a standard device of Windows Vista? Can I remove it? > > > > I have the same problem with Windows Vista not regconizing my PenDrive. > > may > > I know what do you mean by "deleting them in device manager and/or > > reinstalling them .. " > > > > Thanks > > > Just delete the USB hubs from Device Manager. Vista will rediscover and > reinstall them. > Be sure to delete INFCACHE.1 first. > > |
| USB Memory stick stops working | Vista hardware & devices | |||
| Memory Stick stopped working on one PC only | Vista General | |||
| USB Memory Stick Drive Letter | Vista hardware & devices | |||
| Sony laptop VGN-A690 with memory stick not working with Vista Upgr | Vista General | |||
| USB Memory Stick & Flash Drive | Vista General | |||
