Vista - Reboot problem
Old 06-23-2007   #1 (permalink)
Anie R J Brion
Reboot problem
I have a random problem with rebooting. It happens every now and then
but not all the time.
I have Vista Ultimate and a ATI x1960 (7.5 drivers) with a ViewSonic 20"
TFT full system details can be found here: http://pcspec.brion.co.uk
When I choose "Restart" the PC will shut down then reboot. I get to the
screen with the cycling green blob but when the screen blanks my monitor
power light goes off and on, off and on... Until I fully power off from
the wall switch this will then allow the PC to load properly. Vista does
continue to load whilst the screen is going off/on as I can hear the
startup sounds.
This PC used to have Windows MCE installed on it and never had this
problem. So this looks like a fault with Vista.
I have the latest MS updates installed.
Is there a fix?
TIA
Annie___ (VM BB L)________________________________
http://find-out-more.brion.me.uk - http://email-me.brion.me.uk
Old 06-23-2007   #2 (permalink)
DefecTalisman
Re: Reboot problem
I had something similar in XP though.
I found the problem to be swollen capacitors on my graphics card.
"Anie R J Brion" <no-reply@brion.me.invalid> wrote in message
news:OniAKhXtHHA.412@TK2MSFTNGP04.phx.gbl...
> Hi,
> I have a random problem with rebooting. It happens every now and then but
> not all the time.
> startup sounds.
> Is there a fix?
> TIA
Old 06-23-2007   #3 (permalink)
Anie R J Brion
Re: Reboot problem
My problem only started this Tuesday after clean installing Vista, I
have no other problems with graphics that I can detect.
I have rebooted about 4 times this morning (Program installs and
updates) and the problem has not shown it head.
It is random to when it happens.
Old 06-23-2007   #4 (permalink)
DefecTalisman
Re: Reboot problem
The usual reply, have you got the latest Vista compatible drives for all
your hardware?
news:u1Z36gZtHHA.1164@TK2MSFTNGP02.phx.gbl...
> My problem only started this Tuesday after clean installing Vista, I have
> I have rebooted about 4 times this morning (Program installs and updates)
Old 06-23-2007   #5 (permalink)
Annie R J Brion
Re: Reboot problem
> your hardware?
I have loaded the 7.5 driver for the x1950. MY X-fi has the latest from
creativelabs.
Which other drivers should I check? I have updated with MS Update.
I'm a VM customer and NOT Virgin Media Technical Support!
Reboot problem--very annoying. General Discussion
sp2 reboot problem Windows Updates
Problem : Reboot of Physical PC Virtual PC
connection problem after reboot Vista networking & sharing
Installation reboot problem Vista installation & setup
