| | Why does Vista keep trying to fix my flash drives? It seems that every flash drive or SD card that I plug into my computer isn't quite good enough for Vista--it always asks me whether I want to scan and fix before I use it. I always answer "no" because I don't want to lose the files and Vista seems to be perfectly happy to copy them off without the scan & fix. Is this a new feature of Vista and can it be disabled? Is it really the case that all of my removable storage is corrupted? Thanks in advance! Ryan |
| | Re: Why does Vista keep trying to fix my flash drives? Are you running the flash drive on another computer? That is where your 'errors' may be coming from. Just answer 'yes' and let Vista 'do its stuff' for a couple of seconds and your flash drive will be okay. It is probably that the flash drive was removed from an XP (or earlier) system without going through the <safely remove hardware> routine. It seems that every flash drive or SD card that I plug into my computer isn't quite good enough for Vista--it always asks me whether I want to scan and fix before I use it. I always answer "no" because I don't want to lose the files and Vista seems to be perfectly happy to copy them off without the scan & fix. Is this a new feature of Vista and can it be disabled? Is it really the case that all of my removable storage is corrupted? Thanks in advance! Ryan |
| | Re: Why does Vista keep trying to fix my flash drives? Utter crap. I swap my flash drive between an XP and a Vista computer with no probs. "majmac" wrote: > > Are you running the flash drive on another computer? That is where your > 'errors' may be coming from. > Just answer 'yes' and let Vista 'do its stuff' for a couple of seconds > and your flash drive will be okay. > It is probably that the flash drive was removed from an XP (or earlier) > system without going through the <safely remove hardware> routine. > > > Ryan;359992 Wrote: > > It seems that every flash drive or SD card that I plug into my computer > > isn't > > quite good enough for Vista--it always asks me whether I want to scan > > and fix > > before I use it. I always answer "no" because I don't want to lose the > > files > > and Vista seems to be perfectly happy to copy them off without the scan > > & > > fix. Is this a new feature of Vista and can it be disabled? Is it > > really > > the case that all of my removable storage is corrupted? > > > > Thanks in advance! > > > > Ryan > > > -- > majmac > > AMD64x2 4600+ > |
| | Re: Why does Vista keep trying to fix my flash drives? Do you actually have a useful suggestion as to the cause, or do you just assume the info provided is not correct because you don't have the specific problem? It is not utter crap, the scenario provided can cause the OP's problem, I've run into it myself, so rather than bashing peoples replies, perhaps you should spend the time getting a clue as to what your talking about so you don't look like an unknowledgeable troll. -- ---- Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm How to ask a question http://support.microsoft.com/kb/555375 How to Post http://www.dts-l.org/goodpost.htm ---------------------------------------------------------------------------------------------------------------------- "Mick" <Mick@discussions.microsoft.com> wrote in message news:F971DAD7-4F81-4F33-9A90-15AC9B8A7027@microsoft.com... > Utter crap. I swap my flash drive between an XP and a Vista computer with > no > probs. > > "majmac" wrote: > >> >> Are you running the flash drive on another computer? That is where your >> 'errors' may be coming from. >> Just answer 'yes' and let Vista 'do its stuff' for a couple of seconds >> and your flash drive will be okay. >> It is probably that the flash drive was removed from an XP (or earlier) >> system without going through the <safely remove hardware> routine. >> >> >> Ryan;359992 Wrote: >> > It seems that every flash drive or SD card that I plug into my computer >> > isn't >> > quite good enough for Vista--it always asks me whether I want to scan >> > and fix >> > before I use it. I always answer "no" because I don't want to lose the >> > files >> > and Vista seems to be perfectly happy to copy them off without the scan >> > & >> > fix. Is this a new feature of Vista and can it be disabled? Is it >> > really >> > the case that all of my removable storage is corrupted? >> > >> > Thanks in advance! >> > >> > Ryan >> >> >> -- >> majmac >> >> AMD64x2 4600+ >> |
| | Re: Why does Vista keep trying to fix my flash drives? On Jun 26, 5:42 am, Mick <M...@discussions.microsoft.com> wrote: > Utter crap. I swap my flash drive between an XP and a Vista computer with no > probs. Well, this is good for you. But... I too get the Scan and Fix dialog whenever I pop in my camera, ipod ir thumbdrive. I tried scanning and fixing the ipod, but it still comes up with that warning each time. What I would like is the option to not have the dialog come up. It gets quite tedious. |
| Vista will not read flash drives using FAT | Vista General | |||
| Use of External Hard Drives and Flash USB Drives | Vista hardware & devices | |||
| USB Flash Drives for 64 Bit Vista Home Premium | Vista hardware & devices | |||
| can' t copy to flash drives or external hard drives with USB ports | Vista General | |||
| Do USB Flash Drives have to be safely removed in Vista? | Vista hardware & devices | |||
