Vista - Start menu power button
Old 06-26-2007   #1 (permalink)
Amit Shah
hello
does anyone know how to change the start menu's power button to make it turn
off instead of sleep.
thank in advance.
Old 06-26-2007   #2 (permalink)
P. Di Stolfo
Re: Start menu power button
Hello,
go to Control Panel -> Hardware and Sound -> Power Options -> System
settings. There, you'll find the setting.
Greetings,
P. Di Stolfo
"Amit Shah" <amwam@hotmail.co.uk> wrote in message
news:C0004BC8-6F2D-4FB9-B7C8-7B716E46B0DB@microsoft.com...
> hello
> turn off instead of sleep.
> thank in advance.
Old 06-27-2007   #3 (permalink)
Lang Murphy
> hello
> thank in advance.
Click Start Orb
Type "power" in the search box
Click on "Power Options" in the list
Click on the "Change plan settings" link for your active power plan
Click on "Change advanced power settings" link
Expand "Power buttons and lid"
Expand "Start menu power button"
Change settings for "On battery" and "Plugged in" as appropriate. (Click on
the current setting... that will bring up a drop down menu that will allow
you to change from Sleep to either Shut down or Hibernate...)
Lang
Solved How do I Re-instate the Power Button to the Start Menu General Discussion
Power button in the Start menu Vista General
Re: Start Menu Power Button Issue Vista General
Power button on Start Menu Vista General
Start Menu power button action Vista General
