| | Vista - USB Drive Problems |
| 06-27-2007 | #1 |
| | USB Drive Problems Hello All... I come to MS after trying to work with Gateway several times on this issue but they tell me its a Vista issue and not their problem. GREAT!! Anyways...a couple months ago I purchased a Gateway MT3705 laptop which came with Vista home premium. I used an external powered LaCie USB hard drive on my desktop for backups and figured that would be a good way to move some data around. However I learned that after a couple minutes or even sometimes when I plugged in the drive to my laptop I would get the message that this device can perform faster on USB 2. Or if the drive was already plugged in and copying files the drive would disconnect as a USB 2 device and reconnect as USB 1.1 thus slowing down everything to a crawl and causing problems with a data copy. So just to make sure it wasn't some weird HD error with vista I ordered a brand new usb memory stick (1 GB) and experienced the exact same problem! Now I am to the point where I NEED to start using some external storage for backups and other stuff however when I plug in my new WD passport drive I bought today I once again am experiencing the same issue. All of these drives will work fine on my desktop running XP Pro but the minute I try using them on my laptop they are flakey. Does anyone have any suggestions other than trying to down grade this laptop to XP? I have also tried different USB cables if they were being used. |
| My System Specs |
| 06-27-2007 | #2 |
| | Re: USB Drive Problems On Jun 26, 11:16 pm, DJ-Ryan <JeepThing...@gmail.com> wrote: > Hello All... > > I come to MS after trying to work with Gateway several times on this > issue but they tell me its a Vista issue and not their problem. > GREAT!! > > Anyways...a couple months ago I purchased a Gateway MT3705 laptop > which came with Vista home premium. I used an external powered LaCie > USB hard drive on my desktop for backups and figured that would be a > good way to move some data around. However I learned that after a > couple minutes or even sometimes when I plugged in the drive to my > laptop I would get the message that this device can perform faster on > USB 2. Or if the drive was already plugged in and copying files the > drive would disconnect as a USB 2 device and reconnect as USB 1.1 thus > slowing down everything to a crawl and causing problems with a data > copy. So just to make sure it wasn't some weird HD error with vista I > ordered a brand new usb memory stick (1 GB) and experienced the exact > same problem! Now I am to the point where I NEED to start using some > external storage for backups and other stuff however when I plug in my > new WD passport drive I bought today I once again am experiencing the > same issue. All of these drives will work fine on my desktop running > XP Pro but the minute I try using them on my laptop they are flakey. > > Does anyone have any suggestions other than trying to down grade this > laptop to XP? I have also tried different USB cables if they were > being used. Sorry...I realize I should have posted this in the hardware forum. Please respond there if you would like to give a response. |
| My System Specs |
| 06-27-2007 | #3 |
| | Re: USB Drive Problems If I were you, I'd try updating the drivers for your laptop. I would start with the motherboard chipset, (I only see ChipsetFAQ.exe - not sure if that's just a help file or what), then I would perhaps try a BIOS update if it's not up-to-date and you are comfortable doing BIOS updates (if you mess up a BIOS update, it's sometimes a big deal). Maybe check your BIOS first as well to ensure that USB2.0 is enabled. Cheers "DJ-Ryan" <JeepThingGuy@gmail.com> wrote in message news:1182917772.522721.86330@w5g2000hsg.googlegroups.com... > Hello All... > > I come to MS after trying to work with Gateway several times on this > issue but they tell me its a Vista issue and not their problem. > GREAT!! > > Anyways...a couple months ago I purchased a Gateway MT3705 laptop > which came with Vista home premium. I used an external powered LaCie > USB hard drive on my desktop for backups and figured that would be a > good way to move some data around. However I learned that after a > couple minutes or even sometimes when I plugged in the drive to my > laptop I would get the message that this device can perform faster on > USB 2. Or if the drive was already plugged in and copying files the > drive would disconnect as a USB 2 device and reconnect as USB 1.1 thus > slowing down everything to a crawl and causing problems with a data > copy. So just to make sure it wasn't some weird HD error with vista I > ordered a brand new usb memory stick (1 GB) and experienced the exact > same problem! Now I am to the point where I NEED to start using some > external storage for backups and other stuff however when I plug in my > new WD passport drive I bought today I once again am experiencing the > same issue. All of these drives will work fine on my desktop running > XP Pro but the minute I try using them on my laptop they are flakey. > > Does anyone have any suggestions other than trying to down grade this > laptop to XP? I have also tried different USB cables if they were > being used. > |
| My System Specs |
| 06-27-2007 | #4 |
| | Re: USB Drive Problems http://www.windowsvistamagazine.com/...-computer.html try this first http://www.bleepingcomputer.com/tuto...torial136.html if no joy see disable "DJ-Ryan" <JeepThingGuy@gmail.com> wrote in message news:1182917772.522721.86330@w5g2000hsg.googlegroups.com... > Hello All... > > I come to MS after trying to work with Gateway several times on this > issue but they tell me its a Vista issue and not their problem. > GREAT!! > > Anyways...a couple months ago I purchased a Gateway MT3705 laptop > which came with Vista home premium. I used an external powered LaCie > USB hard drive on my desktop for backups and figured that would be a > good way to move some data around. However I learned that after a > couple minutes or even sometimes when I plugged in the drive to my > laptop I would get the message that this device can perform faster on > USB 2. Or if the drive was already plugged in and copying files the > drive would disconnect as a USB 2 device and reconnect as USB 1.1 thus > slowing down everything to a crawl and causing problems with a data > copy. So just to make sure it wasn't some weird HD error with vista I > ordered a brand new usb memory stick (1 GB) and experienced the exact > same problem! Now I am to the point where I NEED to start using some > external storage for backups and other stuff however when I plug in my > new WD passport drive I bought today I once again am experiencing the > same issue. All of these drives will work fine on my desktop running > XP Pro but the minute I try using them on my laptop they are flakey. > > Does anyone have any suggestions other than trying to down grade this > laptop to XP? I have also tried different USB cables if they were > being used. > |
| My System Specs |
| 06-27-2007 | #5 |
| | Re: USB Drive Problems On Jun 26, 11:29 pm, "Duncan" <dun...@discussions.microsoft.com> wrote: > If I were you, I'd try updating the drivers for your laptop. I would start > with the motherboard chipset, (I only see ChipsetFAQ.exe - not sure if > that's just a help file or what), then I would perhaps try a BIOS update if > it's not up-to-date and you are comfortable doing BIOS updates (if you mess > up a BIOS update, it's sometimes a big deal). Maybe check your BIOS first as > well to ensure that USB2.0 is enabled. > > Cheers > > "DJ-Ryan" <JeepThing...@gmail.com> wrote in message > > news:1182917772.522721.86330@w5g2000hsg.googlegroups.com... > > > > > Hello All... > > > I come to MS after trying to work with Gateway several times on this > > issue but they tell me its a Vista issue and not their problem. > > GREAT!! > > > Anyways...a couple months ago I purchased a Gateway MT3705 laptop > > which came with Vista home premium. I used an external powered LaCie > > USB hard drive on my desktop for backups and figured that would be a > > good way to move some data around. However I learned that after a > > couple minutes or even sometimes when I plugged in the drive to my > > laptop I would get the message that this device can perform faster on > > USB 2. Or if the drive was already plugged in and copying files the > > drive would disconnect as a USB 2 device and reconnect as USB 1.1 thus > > slowing down everything to a crawl and causing problems with a data > > copy. So just to make sure it wasn't some weird HD error with vista I > > ordered a brand new usb memory stick (1 GB) and experienced the exact > > same problem! Now I am to the point where I NEED to start using some > > external storage for backups and other stuff however when I plug in my > > new WD passport drive I bought today I once again am experiencing the > > same issue. All of these drives will work fine on my desktop running > > XP Pro but the minute I try using them on my laptop they are flakey. > > > Does anyone have any suggestions other than trying to down grade this > > laptop to XP? I have also tried different USB cables if they were > > being used.- Hide quoted text - > > - Show quoted text - Duncan... Thanks for the response. I have already tried any updates that Gateway has on their site. Ryan |
| My System Specs |
| Similar Threads for: USB Drive Problems | ||||
| CD Drive Problems | Vista General | |||
| Problems installing Vista on SATA drive as third master drive | Vista installation & setup | |||
| CD/DVD Drive Problems | Vista General | |||
| CD/DVD Drive Problems | Vista hardware & devices | |||
| CD Drive problems | Vista General | |||
