Vista Tutorial - Display Problems on Certain Websites
Old 06-27-2007   #1 (permalink)
KC
Guest
I have a new Dell w/IE running on Vista. A couple of websites (of course,
ones I need to use frequently) are not loading properly. Color-coding used
to highlight data, table gridlines and a search box are missing.
- IE accessibility tab -colors and fonts options are set to allow for
website choices.
- I have run a repair using the Vista DVD - no problems found.
- I restored to an earlier time - no help for this problem.
- Downloaded a second browser - same problem on same sites.
- reinstalled graphics drivers
- checked another machine using IE on XP - no problems, websites display
properly w/out missing formatting
I have to conclude that it is a Vista issue. It has been suggested that the
style sheets for these web pages are being suppressed.
Does anyone know how to allow those stylesheets???? (At least one of the
web pages is most important that I access properly.)
THank you.
Old 06-27-2007   #2 (permalink)
Mick
Guest
RE: Display Problems on Certain Websites
1 It could be the way the sites are written.
2 Is up-to-date Flash installed on your comp?
> website choices.
> THank you.
Old 06-27-2007   #3 (permalink)
Rick Rogers
Guest
Re: Display Problems on Certain Websites
Can you give a link to one of the sites with issues?
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"KC" <KC@discussions.microsoft.com> wrote in message
news:2F80B22E-36D2-4211-A2E7-C147B9F26DFF@microsoft.com...
> used
> website choices.
> the
> THank you.
Old 06-27-2007   #4 (permalink)
KC
Guest
1- I've been in contact w/ the webmasters for the sites. They are trying to
troubleshoot but nothing so far.
2- I'm sorry. what exactly is up-to-date flash?
> > website choices.
> > THank you.
Old 06-27-2007   #5 (permalink)
KC
Guest
Yes,
1- www.optionetics.com (the biggest problem is in the web-based application
I log into though some of the basic website is off as well)
2- www.audible.com (complete search box is missing in help section plus
site, in general, looks like text as compared to HTLM)
Thank you for any help.
"Rick Rogers" wrote:
> Hi,
> Best of Luck,
> > used
> > website choices.
> > the
> > THank you.
Display Problems General Discussion
display problems Vista General
Display problems with certain websites II Vista General
Display Problems Vista General
"Internet Explorer cannot display the webpage" for some websites Vista General
