Vista Tutorial - installation problem
Old 06-22-2006   #1 (permalink)
windows vista install stalls
Guest
after copying files windows restarts and then stalls on the boot screen
what can i do
Old 06-22-2006   #2 (permalink)
Rick Rogers
Guest
Re: installation problem
Is there any drive activity, even if it's intermittent? If so, then it is
probably progressing, allbeit slowly. Remember, this is a beta product and
not everything functions correctly. I've had a few installs, particularly on
3-4 year old hardware, that took more than 3 hours to complete and often
appeared stalled.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"windows vista install stalls"
<windowsvistainstallstalls@discussions.microsoft.com> wrote in message
news:57CFABC7-C945-46D4-B476-060A597FEF37@microsoft.com...
> what can i do
Old 06-22-2006   #3 (permalink)
Mark Van Noy
Guest
It would also be helpful, potentially, to know what hardware you are running
on. As for trying to get the install running faster, most of the install
hangs and slowdowns occur during the phase when Vista is trying to determine
hardware and drivers. You might have better luck with the initial install if
you pull any non-essential PCI cards out of the computer before doing the
install. After the install is complete you can add the cards back in one by
one to hopefully find the one that is causing you grief. Of course, I am
assuming that you are working with a desktop system. You might try
alt-tabbing when it seems hung to see if there are any error messages being
hidden behind the install screeen as well.
"Rick Rogers" wrote:
> Hi,
> appeared stalled.
> Best of Luck,
> > what can i do
I am at my end with the installation problem Vista installation & setup
Installation problem General Discussion
Problem in installation! General Discussion
installation problem General Discussion
Installation problem Vista installation & setup
