Vista - Resume attachment problem
Old 06-28-2007   #1 (permalink)
Sandy
I created a resume in Word that looks and prints out perfectly. However,
when I send it as an attachment the people receiving it say that the resume
looks fine except that the cursor shows up on it! What am I doing wrong?
Thanks in advance
Old 06-28-2007   #2 (permalink)
Tim Judd
Re: Resume attachment problem
> Thanks in advance
It's a MS Word document, the cursor will always show up unless you make
it in a format that isn't writable (think HTML or PDF as an example. I
don't recommend letting Word saving the file as HTML format, it will
butcher the format so only MSIE can render it. Firefox or other
browsers will give up on the HTML file. Other examples are GIF images
or the like).
As long as you're sending the file as a .doc -- others can modify your
resume. This can very possibly be the reason PDF format resumes are
gaining popularity over .DOC
HTH
Old 06-28-2007   #3 (permalink)
Sandy
Fantastic Tim...you have been a big help!
> > Thanks in advance
> or the like).
> HTH
Vista S3 resume from sleep problem Vista General
Resume from standby problem Vista hardware & devices
Weather Gadget problem with Sleep & Resume Vista General
Problem with resume (from S3 standby/sleep) Vista General
S3 problem- Resume from S3 - PS2 keyboard and mouse not functionin Vista hardware & devices
