Vista - Problem with activation after replacement of HDD
Old 06-29-2007   #1 (permalink)
Dirk-Jan Mulder
I bought Windows Vista Home Premium for my notebook. Everything worked fine.
I've had some trouble with my HDD. I send my notebook to the repaircenter en
got I returned with a new HDD. I reinstalled Windows Vista. And now
activation fails because the code was already in use. is there a way to get
it reactivated?
thanks in advance,
Dirk-Jan
The Netherland
Old 06-29-2007   #2 (permalink)
Mark Veldhuis
Re: Problem with activation after replacement of HDD
In article <64C37182-0B38-4A9B-AECF-66D77275A18F@microsoft.com>, =?Utf-
8?B?RGlyay1KYW4gTXVsZGVy?= <Dirk-Jan Mulder@discussions.microsoft.com>
says...
> it reactivated?
> thanks in advance,
> Dirk-Jan
> The Netherland
Activate by telephone. If the automated system is unable to help you,
you'll get to speak to a real person who will give you the code to
reactivate your copy of Vista.
Met vriendelijke groet,
Mark Veldhuis.
Old 06-29-2007   #3 (permalink)
Dirk-Jan Mulder
Dankje, het is gelukt!
"Mark Veldhuis" wrote:
> Hi,
> says...
> > it reactivated?
> > thanks in advance,
> > Dirk-Jan
> > The Netherland
> Mark Veldhuis.
Old 06-29-2007   #4 (permalink)
Ronnie Vernon MVP
Dirk
This same problem is posted on these groups several times a day.
The online activation fails and tells you that this product key is already
in use simply because 'you' have already activated with this product key.
The instructions on the activation window gives you the option to use the
telephone to activate when this happens. When you select this option a local
telephone number will be displayed. Call the number and speak to a
representative. They will give you a new activation code. This takes about 5
minutes.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
"Dirk-Jan Mulder" <Dirk-Jan Mulder@discussions.microsoft.com> wrote in
message news:64C37182-0B38-4A9B-AECF-66D77275A18F@microsoft.com...
>fine.
> en
> get
> it reactivated?
> thanks in advance,
> Dirk-Jan
> The Netherland
disk replacement, vista ask new activation ? Vista installation & setup
Activation problem Vista General
Activation problem Vista installation & setup
Activation Problem Vista General
