| | Vista - Mouse problems |
| 06-30-2007 | #1 |
| | Mouse problems Hi guys I have a cheap walmart mouse that worked perfectly until about 15 minutes ago. I have updated nothing. Downloaded nothing. Installed nothing. The scroll wheel simply stopped working It works if you click it for fast full screen movement, and everything wlse is fine....just not the scroll wheel. I know the mouse isn't bad, I plugged it into my laptop and it works fine. I haven't tried uninstalling because I don't have another mouse to use while this one is out and I was afraid no drive would render me mouse-less and stuck. I did try to update the drivers but everything is current/ |
| My System Specs |
| 06-30-2007 | #2 |
| | Re: Mouse problems Check connection, turn computer OFF..... wait a couple ,,,, turn ON. If no joy check Control Panel - Mouse "mjp1531" <mjp1531@discussions.microsoft.com> wrote in message news:7E4AA33B-402C-4F69-BC44-8EB2DC76A462@microsoft.com... > Hi guys I have a cheap walmart mouse that worked perfectly until about > 15 > minutes ago. I have updated nothing. Downloaded nothing. Installed > nothing. The scroll wheel simply stopped working It works if you click > it > for fast full screen movement, and everything wlse is fine....just not the > scroll wheel. I know the mouse isn't bad, I plugged it into my laptop and > it > works fine. I haven't tried uninstalling because I don't have another > mouse > to use while this one is out and I was afraid no drive would render me > mouse-less and stuck. I did try to update the drivers but everything is > current/ |
| My System Specs |
| 06-30-2007 | #3 |
| | Re: Mouse problems SOMETIMES I HAVE PLUGGED THEM INTO A DIFFERENT USB PORT AND THEY WORK FINE ON REDETECTION "mjp1531" <mjp1531@discussions.microsoft.com> wrote in message news:7E4AA33B-402C-4F69-BC44-8EB2DC76A462@microsoft.com... > Hi guys I have a cheap walmart mouse that worked perfectly until about > 15 > minutes ago. I have updated nothing. Downloaded nothing. Installed > nothing. The scroll wheel simply stopped working It works if you click > it > for fast full screen movement, and everything wlse is fine....just not the > scroll wheel. I know the mouse isn't bad, I plugged it into my laptop and > it > works fine. I haven't tried uninstalling because I don't have another > mouse > to use while this one is out and I was afraid no drive would render me > mouse-less and stuck. I did try to update the drivers but everything is > current/ |
| My System Specs |
| Similar Threads for: Mouse problems | ||||
| Mouse Problems | Vista hardware & devices | |||
| Mouse problems ? | General Discussion | |||
| mouse problems | Vista hardware & devices | |||
| mouse problems | Vista General | |||
| Mouse problems | Vista General | |||
