Vista - General Question
Old 07-01-2007   #1 (permalink)
Mike Busch
General Question
I have not even looked at Vista, but I will soon be helping a friend with a
laptop for problem he has with Vista. To me it sounds like something that
might have already been addressed. When he starts his laptop it brings him to
a black screen that just states "Select Enter" to start. Any help. Thanks in
advance.
Old 07-01-2007   #2 (permalink)
Bruce Chambers
Re: General Question
> advance.
Based on your rather sparse description, it sounds like the problem has
absolutely nothing to do with Vista, and everything to do with the
laptop's hardware and/or BIOS configuration. Consult the laptop's
manual or manufacturer.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety. -Benjamin Franklin
Many people would rather die than think; in fact, most do. -Bertrand Russell
Old 07-01-2007   #3 (permalink)
Rick Rogers
Is this after the POST and prior to Windows loading? Or does it appear after
the system has begun to load the hard drive?
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Mike Busch" <wizof103@verizon.net> wrote in message
news:C27A4E29-3E50-433D-8053-10FA2598F9E1@microsoft.com...
> to
> in
> advance.
Old 07-01-2007   #4 (permalink)
ray
> advance.
Press the 'enter' key?
General question... General Discussion
WLM General Question Live Mail
General question about this NG Vista General
General question PowerShell
