Vista - Shadow Copies (Previous versions) of files do not work?
Old 07-01-2007   #1 (permalink)
Alexander
Hi everybody! Just another one problem and question if I do everything
correctly or no.
I've read a lot about the so-called Shadow Copies (previous versions) od
files, documents etc. But I can't figure out how to make it fork on my
system.
Here is my situation: I use Vista Ultimate Russian so function should work
for this version of Windows. I have some Excel file that I work with every
day making some everyday changes to it. It's located inside subfolder in My
Documents folder.
I've enabled Automatic restore points for both my logical drives.
BUT when I go to properties of my Excel file and select the tab Previous
Versions it says me that there is NO previous versions for this file. For
several months I work with this file every day changing it but it never
showed me any previous versions. I specially played with other files testing
the feature but also no success.
The system restore function itself works well.
Old 07-02-2007   #2 (permalink)
Lang Murphy
Re: Shadow Copies (Previous versions) of files do not work?
"Alexander" <al_butenko_n_o_s_p_a_m@mail.ru> wrote in message
news:B3EA896E-0C5A-4A6D-82AB-95E6B926DAF4@microsoft.com...
> correctly or no.
> system.
> work for this version of Windows. I have some Excel file that I work with
> every day making some everyday changes to it. It's located inside
> subfolder in My Documents folder.
> testing the feature but also no success.
Are you dual booting with XP?
Lang
Old 07-06-2007   #3 (permalink)
Alexander
Hi! No. As I've said I have no problems with system restore in general (if I
dual-boot system restore won't work as it's described in help) but I don't
use XP.
May be this matters - when I first installed Vista it was dual-boot but then
I removed XP and reformatted XP's volume so now I don't have dual-boot. And
once again System Restore works Ok but Shadow Copies simply don't work...
"Lang Murphy" <lang_murphy@hotmail.com> сообщил/сообщила в новостях
следующее: news:73006E4C-0B01-44D5-9626-B262954A21CD@microsoft.com...
>> correctly or no.
>> system.
> Lang
Previous Versions - Shadow Copy Tutorials
Removing previous versions of files Vista file management
Shadow copies absolutely refuse to work Vista General
Shadow copies does not work!! Vista General
╘ Designer Media Ltd
