Vista - Typing traditional charecters using Pinyin
Old 07-02-2007   #1 (permalink)
Zak
Hello, I would like to type traditional Chinese characters (used in Taiwan)
with the Pinyin input system that is available for simplified characters. I
was able to do this on windows XP using the language bar, but am unable to do
this in Vista using the same process.
Any help would be much appreciated!
Old 07-03-2007   #2 (permalink)
Mentos
RE: Typing traditional charecters using Pinyin
i use english version of vista home basic and same problem. i want to key in
both simplified and traditional chinese with pinyin.
solution: in control panel > regional and language options > keyboards and
languages, click "change keyboards". In 'installed services', install CH
(chinese PRC) with keyboard and "chinese simplified - microsoft pinyin IME"
so once installed, when you use CH (PRC)as input language, go to tool menu
"options", and in the second tab (MSPY New Experience & Classic input style),
just choose between simplified and traditional chinese 'character set'
MS SBS 2003 SP2
Old 07-05-2007   #3 (permalink)
Zak
thanks for taking the time to reply! I tried this and was able to change it
to traditional in the options menu, but when i type many of the characters
still seam simplified. Strangely enough, I can type words such as Taiwan
using traditional characters if I scroll through the list; however words such
as "xie xie" still show up with a simplified "yen" radical on the left.
> MS SBS 2003 SP2
Old 07-05-2007   #4 (permalink)
Mentos
hi zak, i have tested with MS Word 2003 and if i just change the character
set option (from simplified to traditional), then xie xie is correct for both
simplified and tradtional - ie the left hand radical changes accordingly. i
cant make my system produce the wrong result you are receiving.
sorry, i cant offer any more advice other than experimenting with the
language tool options. it must be something there because my vista works just
fine.
PS: my vista patches are up to date. you might want to check yours are
updated as well.
MS SBS 2003 SP2
> > MS SBS 2003 SP2
Chinese Pinyin IME stops functioning after a while Vista General
Traditional Chinese IME Handwriting Vista General
Solitaire Face Cards- no traditional? Vista General
Re: Xp Pro and Vista non traditional dual boot Vista installation & setup
