Vista - Detail pane does not display album art
Old 07-03-2007   #1 (permalink)
Ian
I have a problem where the detail pane in Vista explorer does not always
display the album art next to the item and displays the MP3 picture. It
strange because if I go into an album folder some of the items will have the
correct pictures and others won't. All of the art is in Media Player.
Any ideas?
Thanks
Old 07-06-2007   #2 (permalink)
EscapePod
RE: Detail pane does not display album art
Hello Ian, I don't know if this helps, but I'm pretty sure you will only see
the album art in the views: Extra Large Icons, Large Icons, Medium Icons,
Small Icons, and Tiles. You will not see the art in List or Details views.
escapepod
> Any ideas?
> Thanks
Error Updating File Properties from the Detail Pane Vista file management
image is not thumbnailing in detail pane Vista music pictures video
Details Pane not enough detail Vista music pictures video
Music Detail folder not updating album image(s) Vista music pictures video
Bug: Click on Explorer's Detail pane sometimes doesn't activate wi Vista General
