| | Vista - need help with vista home premium |
| 07-03-2007 | #1 |
| | need help with vista home premium whenever i try to start windows defender a box popup saying that application failed to initialize, ox80070002.need any help that i can get please i'm running windows vista. |
| My System Specs |
| 07-03-2007 | #2 |
| | Re: need help with vista home premium I've noticed that this update for Vista actually re-creates/re-modifies all the files under C:\Program Files\Windows Defender, which are necessary to run Defender. (The update also resets files under C:\ProgramData\Microsoft\Windows Defender\Definition Updates\Default). In other words, it appears to essentially re-install Defender for Vista: http://www.microsoft.com/downloads/d...displaylang=en Too, the update also creates two new folders in C:\Windows\winsxs, which would be used by the System File Checker utility. I would try downloading and installing the update, first. If Defender still doesn't work, try the System File Checker, by right-clicking on Command Prompt (Start Menu\Programs\Accessories), and choosing Run as Administrator. At the prompt, type the following: sfc /scannow Press enter on your keyboard. The scan may take awhile. "muttie" <muttie@discussions.microsoft.com> wrote in message news:A72535C4-C27C-48B3-8B00-7BBBDB33AFDD@microsoft.com... > whenever i try to start windows defender a box popup saying that > application > failed to initialize, ox80070002.need any help that i can get please > i'm running windows vista. |
| My System Specs |
| Similar Threads for: need help with vista home premium | ||||
| UPgrade to Win 7Home premium from Win Vista Home Premium. | Vista installation & setup | |||
| Remote Access from Vista Home Premium to Vista Home Premium and XP Home Edition | Network & Sharing | |||
| Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H | Vista General | |||
| I think I finially got my friends XP Home and Vista Home Premium machines to Share | Vista networking & sharing | |||
| Windows XP Home (Full Vers.) to Vista Home Premium Upgrade (Academ | Vista General | |||
