| | oasadgenerator.aspx help Hi when ever i open my IE i get this do you want to save this file .or find a program online to open it. name oasadgenerator.aspx type unknown file type 664 bytes from publish.vx.roo.com when i go to that site i get cannot dispay the webpage. does anyone know what this file is? and if so what do i need it if how do i open it? thank you |
| what does /defaultc.aspx mean on my address? | General Discussion | |||
| Cant run aspx locally | .NET General | |||
| .ASPX Extension | .NET General | |||
| Failure to open .aspx files | Vista file management | |||
| Automation of aspx modification. | PowerShell | |||
